To use objects with objecttags for movement, opacity, layer/object id, etc... You should select render method2: "resend only updated objects". This method is default anymore to be away this kind of user feedbacks. Thankscbmotion wrote:Hi Ahmet -
again - thank you for your excellent work!!!!! i love octane
But your rendermask-sample1 build only one mask at my render. ist this a mac problem/bug?
i didnt change anything in the settings
cheers
carsten
Version 2.20.0 RC2 - Release candicate 2
Thx. Hopefully it will be better on every system font setups.garytyler wrote:I've only had this open for 5 minutes but so far the sliders seem to be updating perfectly!!! Also, the new overlay and rendering bar looks great. Thank you Ahmed!!!
- shawnfrueh
Hey Aoktar, I can confirm the issue with the Stop button. I am using the latest version posted here after someone else had brought up this issue. I normally don't use stop but it seems that after pressing the stop button I can no longer use the send button. If I open the dialog on its own and use the send button I can then close that and use the LV Dialog like normal unless I press the stop button again.
I really like the updated Stats bar! Great work!
Hi Aoktar,
I experienced an issue of the use of the new version, when using C4D happen frequent freezing of the work and I just have to use CTR ALT DEL and restart C4D.
I think this happens because I noticed that sometime opens unexpectedly Live Viewer 2.14 even though it is running Live Viewer 2.20 RC2.
It could be due to an incomplete uninstall the plug-in, even if I removed everything from the plugin folder of Octane, as with every new release.I believe, however, that it remained some trace in interface customization.
Have you any suggestions? I can no longer work!
i have no idea about your system details and workflow. Try to remove all plugins(also octane), make a clean install. Change your driver to latest. Don't save octane windows to layout.augdalmo wrote:Hi Aoktar,
Hallo Aoktar,
many thanks for the fast reply.
my system WIN 8.1 64 bit X5460 16GB C4D R16 GTX780 Titan Black 6GB + K2000 2GB, I will try your suggestions, for the first I have removed my template with Octane Icon, if the problem will be solved I will inform you.
I have noticed that the icon of Octane Dialog and Octane Live viewer ar the same, why?
- eyeonestudio
- Contact:
Standalone Development Build Releases 2.21 is Out....
Finally~~ Out-of-core Textures
Thanks.. abstrax & aoktar
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
AHMET, THE GREATEST!!!
Almost of you, don't understand what I mean...
Thank you Ahmet!
L
Thank you Ahmet!
L
- Schermata 2015-02-06 alle 16.22.42.png (28.38 KiB) Viewed 6576 times
Mac Pro 5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
thanks. Can't understand what i should see here!lucioing wrote:AHMET, THE GREATEST!!!
Thank you Ahmet!
L
