What next ? FBX or Collada
If you are planning to implement both then great
The more options the better IMHO, opening up to a wider audience has got to be a good thing.
Win 7 Pro (x64) | Geforce 295GTX | Quad 2.4GHz | 4GB PC-6400
Hi guys,
If we decide to implement COLLADA,
what version should we implement ?
i understand there's currently version 1.3 and 1.4.
It would be handy if people could post here and explain which version your 3d application can export to.
I'd like to have a short overview of the versions that are supported so we can decide which version to implement.
I don't think it's forward compatible, although i'm not sure.
Need to do some more reading
Radiance
Radiance
First, COLLADA has version 1.5.0, too.
I need COLLADA mainly for SketchUp, because all other modeling tools i use, have good .obj support.
After reading that Wikipedia web-page, i have found the following:
The details for the compatibility between 1.4.0 and 1.4.1 can be found here. (PDF)
That means for me that Octane needs support for the 1.4 (1.4.0 or 1.4.1) version of COLLADA.Google Earth (release 4) has adopted COLLADA (1.4) as its native format for describing the objects populating the earth. Users can simply drag and drop a COLLADA (.dae) file on top of the virtual Earth. Alternatively, Google SketchUp Pro can also be used to create.kmz files, a zip file containing a KML file, a COLLADA (.dae) file, and all the texture images.
Win XP 32 | Geforce GT240 + Onboard 8200 (Driver ver. 197.13 )| Phenom 9550 | 2GB
radiance,
I use Modo and it support Collada 1.4.1, so does blender and Softimage XSI - i think most DCC app current support 1.4.1 even though 1.5 is the most recent version.
edit:sketchup 7.1(current version) support 1.4.1....according to google
Yes. At least that is written in that official press release.
There are mentioned other interesting applications as SOFTIMAGE|XSI, Maya, Max, Blender, Houdini and Unreal Engine 3.
The press release is old, though. Thus, please see for yourself if something is not changed meanwhile.
- gpu-renderer
If you are aiming for a low end (cost) market its best to provide formats for the low cost 3d editors. Most people cant afford autocad, 3dsmax, maxell, maya etc.
Blender
Sketchup pro
3d bonsai (awsome little package)
Wings 3d
A format they all have in common.
Between that lot maybe a few million users. ( the expensive packages wont sell as fast as the low end ones) Numbers dictate one thing but affordability in large numbers is easier to market to than high end users only)
How many people have triple SLI with water coolers (not many)
How many people have mid range pcs (216 core) pcs .....far more.
From a business point of view your software market should coincide within the same market level and you will sell far more.
Don't get me wrong the more formats you support the better but for now priority would be for the low end 3d software editors.
My 2 cents
Blender
Sketchup pro
Wings 3d
My 2 cents
i7 920 2.66ghz quad core, gtx 285, asus p6t, 6gb OCZ 1600mhz ram, Windows 7 64bit ultimate. Nvidia cuda Driver v3 Nvidia display drivers V193.13. Octane beta 2
Collada...
So I can post in every sketchup forum on earth about Octane
Im just kidding, I use OBJ myself so for now I don't need those files formats
But I think Collada would make more buzz and good advertising than FBX
Just flip a coin, heads = collada, tails = FBXradiance wrote:although i'm not %100 decided yet,
we are going to implement both COLLADA and FBX in the short term.
i'm just not sure yet which one we'll start on first.
Radiance
