OctaneRender 2 for Modo [OBSOLETE]
funk
Thanks for the update Paul!
face_off wrote: - Octane Specular and Glossy Material "roughness" is now the Modo Material roughness * 0.6
I just want to point out that when I came up with that conversion I only tested modo roughness to octane glossy roughness. I didnt test modo refraction roughness to octane specular roughness (which Paul also added) but it seems to match well too.
The only issue people need to be aware of is that in modo, the reflection and refraction roughness are controlled separately. This cannot be done in octane specular materials, so octane only uses the modo refraction roughness
Tharso
Is save as preset working? here I can´t save ..dont know why!
I just checked, and it's working OK for me. Can you explain what "can't save" means pls? It is popping an error?
v1adut
Hi Paul,
I am back with the annoying floating buttons windows. Can you please remove it, and put the additional buttons on the setup window, so we can snap the to windows full screen, on 50/50 split on monitors, no I can not use the most of the screen because of this.
I think this is a simple fix, easy to implement. I do not need all these settings double on that floating window,
10x,
Vlad
raybender
v1adut wrote:Hi Paul,
10x,
Vlad
you are not the only one with a specific way of working. others have requested the buttons to be separate from setup window. you can do a lot of work with octane without even having the setup window open.
i would suggest paul placing the missing buttons in the setup window, too and then you could use the rightclick option in the Octane Preferences to get rid of the toolbar.
Win7x64/ Dual Xeon [email protected]/ 48GB RAM/ 2x GTX Titan 6GB/ 1x GTX 670 4GB
http://www.alexbroeckel.com
10x,
Modo->System->Preferences->Rendering->Octane->tick "Rightclick Viewport to open Control Panel" should do this for you.
I think the only button missing from the Setup window is "Reload Texturemaps", which I doubt anyone ever uses.
raybender
using it all the time paul. :) i am using it so often i already wanted to ask if you could not implement an function to reload textures automatically when they change
I'm not sure there would be a reliable way to detect when a texturemap had changed - other than polling the date/time of the files, which I'm not sure would be practical. Is Modo picking up changed texturemaps? Regardless, I will add that button to the Setup frame.
raybender
yes modo does detect texture changes.. so i thought you could just use the modo function, however that works.
OK, I will investigate if this can be done. Perhaps when Modo picks up the change it will raise an event for the plugins.
Return to “Foundry Modo”
