JJTTBB what max version u using? max 11 is pretty stable for us, even rendering heavy scenes on oct.
Nil
							OctaneRender® for 3ds max® v1.0 beta 2.58e[TEST]
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
To Karba and Gabriele.
It seems that this release for some reason draws more power from the psu.
If you remember i wrote that my second gpu fails and it makes the system freeze, on a mouse movement.
I just disconnected one Hd or one dvd rom , or blue ray or only one peripheral (anything it doesn't matter) from the system and the second gpu worked again, with no freeze at all.
Karba is the new version draws by any change more power from the system by making advance calculations or something? Or was it luck from my side and my psu is off?
By the way i changed several psu and i had the same issue. But when i removed one thing it worked again.
Best
Michael.
Best
Michael.
Everything is possible.GDRS wrote:To Karba and Gabriele.
Best
Michael.
I always try to do some speed optimization and may be it started to work a little bit faster and consume more power.
1) Без инстансов это пока не возможно.irrealix wrote:Karba, мне все нравится.
Глюков нет вообще, приятно работать.
Прям супер.
Спасибо!
Хочется 2 простых вещи:
1) автоматическое обновление при перемещении источника света. (возможно кто то захочет иметь возможность включать или выключать эту возможность)
т.е. я хочу в реалтайме видеть как влияет изменение положение источника
2) хоткей на octanrender viewport
2) Я подумаю, как это сделать
trying out the 2013 version...  there is chinese writing under info chanel render kernel, when choosing Channel type, or it looks like chinese..
							3dmax, zbrush, UE
//Behance profile //BOONAR
Max Design 2012 64bit / Win7nildoe wrote:JJTTBB what max version u using? max 11 is pretty stable for us, even rendering heavy scenes on oct.
Nil
AutoCAD,Revit Architecture, Max Design (all 2012) , Moi3D,Maxwell Render,Octane Render
Intel i7-8Gb RAM - Win7x64 - GTX550Ti
- gabrielefx
got you several 1500W psus?GDRS wrote:To Karba and Gabriele.
Best
Michael.
In my machines I have 4x580 3Gb, 4 ssd hd 128Gb, 24Gb, processor, 1 bd powered by one Enermax. You tried with Enermax? I think you got some faulty peripheral.
PT eats more power but is not significant.
						you got all this in one case?? do you have 2 x 1500 psu's in there?gabrielefx wrote:got you several 1500W psus?GDRS wrote:To Karba and Gabriele.
Best
Michael.
Win 7 64 | 3 x GTX 580 | i7 950 | 24GB
