OctaneRender® 2022.1 (updated 11/28)
SSmolak
Coating layer bug on universal material :
Coating remove bumps if there in sheen layer too with bumps connected to it
john_otoy
SSmolak wrote:Coating layer bug on universal material :
I cannot reproduce this, but I also cannot see all your material settings in the video. Please provide simplified scenes in addition to your videos.
I have attached a test scene with bump, sheen bump and coating. It's working as expected. Right click the universal material > render.
Zay
I tried this HDRI https://polyhaven.com/a/je_gray_park .
Doesn't seem like the AI denoiser likes it as it will shift the texture and it's still noisy.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
thanulee
Hey guys,
Texture displacement cannot use the border modes on an image texture.
If i use eg. clamp values or white borders on an image, it still sees that as “wrap around”.
Is that a limitation or a bug? I was told to post here instead of c4d forums.
Let me know! thanks a lot
SSmolak
Here is scene. Please try to increase coating.
It looks like Sheen Bump interfere with Coating.
john_otoy
Zay wrote:I tried this HDRI https://polyhaven.com/a/je_gray_park .
Can you explain what you mean by "shift the texture"? Can you post an image of the main pass so we can compare it?
I noticed this HDRI has a very bright sun which will clip by default. Click settings (spanner icon) on the RGB image node and set the texture import type to 32 bit float. Does this help?
john_otoy
You have attached an OCS which is missing the geometry and textures. Please export an ORBX.
Zay
john_otoy wrote:I noticed this HDRI has a very bright sun which will clip by default. Click settings (spanner icon) on the RGB image node and set the texture import type to 32 bit float. Does this help?
Yes. Setting it to 32bit fixed the problem. Thanks.
SSmolak
john_otoy wrote: You have attached an OCS which is missing the geometry and textures. Please export an ORBX.
john_otoy
thanulee wrote:Hey guys,
Yes, this is a limitation of texture displacement.
