Coating layer bug on universal material :
Coating remove bumps if there in sheen layer too with bumps connected to it
OctaneRender® 2022.1 (updated 11/28)
I cannot reproduce this, but I also cannot see all your material settings in the video. Please provide simplified scenes in addition to your videos.SSmolak wrote:Coating layer bug on universal material :
I have attached a test scene with bump, sheen bump and coating. It's working as expected. Right click the universal material > render.
I tried this HDRI https://polyhaven.com/a/je_gray_park .
Doesn't seem like the AI denoiser likes it as it will shift the texture and it's still noisy.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
Hey guys,
Texture displacement cannot use the border modes on an image texture.
If i use eg. clamp values or white borders on an image, it still sees that as “wrap around”.
Is that a limitation or a bug? I was told to post here instead of c4d forums.
Let me know! thanks a lot
Here is scene. Please try to increase coating.john_otoy wrote:I cannot reproduce this, but I also cannot see all your material settings in the video. Please provide simplified scenes in addition to your videos.SSmolak wrote:Coating layer bug on universal material :
It looks like Sheen Bump interfere with Coating.
Can you explain what you mean by "shift the texture"? Can you post an image of the main pass so we can compare it?Zay wrote:I tried this HDRI https://polyhaven.com/a/je_gray_park .
I noticed this HDRI has a very bright sun which will clip by default. Click settings (spanner icon) on the RGB image node and set the texture import type to 32 bit float. Does this help?
You have attached an OCS which is missing the geometry and textures. Please export an ORBX.SSmolak wrote:Here is scene. Please try to increase coating.john_otoy wrote:I cannot reproduce this, but I also cannot see all your material settings in the video. Please provide simplified scenes in addition to your videos.SSmolak wrote:Coating layer bug on universal material :
Yes. Setting it to 32bit fixed the problem. Thanks.john_otoy wrote:I noticed this HDRI has a very bright sun which will clip by default. Click settings (spanner icon) on the RGB image node and set the texture import type to 32 bit float. Does this help?
john_otoy wrote: You have attached an OCS which is missing the geometry and textures. Please export an ORBX.
Yes, this is a limitation of texture displacement.thanulee wrote:Hey guys,
