Cinema4D version 2020.1.5-R4 (Obsolete stable) 17.10.2020
VladaStevanovic
SSmolak wrote:
bassruettler wrote:
aoktar wrote:I've completely removed this feature. I may bring back with a different way if you used to it and wish back.
I would appreciate that very much, as it gives you good control over your colors.
Yes, it was somewhat good informational feature.
I didn't find it useful for anything, LV need to be minimal as possible!!So this feature is totally unnecessary
nejck
aoktar wrote:
bassruettler wrote:Hi, i like the new zoom feature.
However, this seems to have replaced the gizmo where you could zoom in on an area and get a color value read-out.
Is that gone for good now or has that moved to another shortcut?
+1, I've found it to be quite important for color critical work. Like, very important :) Now I need to copy & paste the image into PS / Affinity to check the values. We also don't have a "copy" button in LV that is quite a few more steps to be honest :\
I would like to point out that I do like the new functionality that you've implemented. The thing is, I think the best thing would be to keep both in.
pxlntwrk
I discover "erratic" behavior with node editor.
I created a material A and a material B.
When I delete material B some nodes of material A also disappear.
I have probably copied some node arrangements from material B to material A or converted material B to sub material to material A ...
But it's a bit of a hassle and I have to check everything all the time.
and the node trees seem to be interconnected under the hood?
Because a simple removal of unused material can lead to a non-correct re-wiring of several materials used in the scene :cry:
Windows10
Cinema4 r21
Octane 2020.1.5
thanks
pxlntwrk.net
thanulee
Silly question, but since i started c4d with octane and i never used any other engine:
When i make a render preset, "Multipass" should be on or off or it doesnt matter?
pxlntwrk wrote:Hi,
Windows10
Cinema4 r21
Octane 2020.1.5
thanks
Nodes will be deleted if they owned by another material. Connecting the copied nodes to a material that will provide they are owned by this material. Do not expect to use one node that can be used for another materials. Except under a composite material system.
thanulee wrote:Silly question, but since i started c4d with octane and i never used any other engine:
No need to set as "ON" if you don't have to use passes.
nikomedia
Really? Still no word about R23 compatibility? Wake up guys!
nikomedia wrote:Really? Still no word about R23 compatibility? Wake up guys!
Was on break! Please be patient
thanulee
Hi I d like to request an override material with exclude/include and pick ur own override like this one here:
https://gumroad.com/l/jvcLu/sale
Its really handy besides the LV options which are great, but sometimes u wanna check complex scenes with other materials and exclude/include as u like.
thanulee wrote:Hi I d like to request an override material with exclude/include and pick ur own override like this one here:
Noted, thanks!
