Cinema4D version 2020.1.3-R2 (Obsolete stable) 24.06.2020
divasoft
aoktar wrote:
divasoft wrote:My previous results were obtained with version 2020.1. And on the 13th frame and all the frames after it, the octane constantly fails. I updated to the last version and the octane was able to work a little longer. now crash occurs on frame 19. Ahmet, can you say something useful or help something?
Probably about RTX core. As I said your problems are not about my side. So what can you do?
You can directly ask to support email for contributing the whole team or send me your scene to me.
But what can I do if it's not happening on me and a core issue? Just pass it to core team and pray for that they can check and reproduce the issue. For my opinions there's some limitations or problems in core for a lot of scattered geometries.
Ahmet, you were right, the problem was in RTX mode. The crashes stopped when I turned it off. Thank you and jayroth.
jayroth2020
You are most welcome!
bang
The xp vertex map animation on x particles is not reflected as octane- vertexmap.
mesut
edit:
sorted out by using other channels of communication.
win7prof. | i7 4930, 32gb | 2*980ti 6g for renderings | 1*660 for displays
Terryvfx
Hi, anyone else having this auto-toggle issue in the node editor?
Octane Toggle Issue.mp4
(2.73 MiB) Downloaded 4082 times
3dworks
Are crash issues with older CPU's (MacPro 5,1 here) fixed in this version? I remember a few weeks ago in a release a new instruction set was used in the cose which was not supported by those older models. I could not read through all new releases but cannot find any mention of this in this latest release.
foureyez
hi all,
I just updated my NVIDIA Studio drivers and now Octane gave me an error: 0 days left in my license. But when I check my status on the OTOY site, it should be available until 2021-01-30.
When I send a scene to the Viewer, C4D crashes...
Please advice. Thank you.
I'm running C4D R21.207 on a Win10 Pro PC (dual RTX 2080Ti), Nvidia Studio Driver 451.77, OctaneRender 2020.1.3, c4doctane 2020.1.3-R2.
UPDATE: Octane doesn't crash anymore, but the O days left remain...
Nvidia Studio driver 451.77 is working correctly here, and it is not related with license.
Please, go to c4d menu Script/Console or Extensions/Console, (Shift+F10), and share a complete screenshot of the panel, thanks.
ciao Beppe
foureyez
bepeg4d wrote:Hi,
ciao Beppe
hi Beppe,
Enclosed the screenshot of the console window.
https://ibb.co/RP8GQz3
Terryvfx wrote:Hi, anyone else having this auto-toggle issue in the node editor?
Detected and fixed for next build. It was a case that happens after you minimize a node
