Yes I can confirm!thanulee wrote:Hi voronoi fracture vertex map selections do not work. Just do a sphere, add voronoi, check "edge vertex map". Then apply this map in diffuse or mix texture and its not working.
Can u confirm? ty
edit: only if i make editable voronoi and assign each vertex map to each fragment, which ofc is out of the question
Version 3.08.2-R3 (obsolete stable)
hello,
i just installed the latest stabel 3.08 and i updated my nvida-driver to version 398.82
and got an errormessage:
Started logging on 13.08.18 14:58:16
OctaneRender 3.08.2 (3080200)
CUDA error 221 on device 1: PTX JIT compiler library not found
-> failed to create link
device 1: failed to create OSL compile context:
error : Unable to load library 'nvptxJitCompiler.dll'
CUDA error 221 on device 0: PTX JIT compiler library not found
device 0: failed to create OSL compile context:
device 0: failed to compile module 0
device 1: failed to compile module 0
should i try another nvidia-driver?
thanks in advance
thanks in advance
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
No, the latest version is 3.08.3HTK421 wrote:What on earth does "Obsolete Stable" mean ?
This appears to be the newest entry on the updates list, so why is it "obsolete" ??
viewtopic.php?f=85&t=68503
C4D 2025 | Win10
Which updates list? This is older stable, so I marked as obselete. Latest stable is actually 3.08.3-R2.HTK421 wrote:What on earth does "Obsolete Stable" mean ?
