Test Version 3.07-Test6a
lancemoody wrote:Here is the scene.
I cannot see any geometry/material/etc.. animations in your scene else of camera fly. So this scene cannot produce any errors in plugin side. Also it's hard to be a bug for renderer core. Please test your scene with 3.06.2 and check your software/hardware setup for stability.
lancemoody
Do you think it could be something to do with that third party CYC?
I eliminated that item (and replaced with a large plane instead) and started a new render.
Previously, I could get a crash to happen readily by simply doing something else while the render was happening.
In this setup--I do not seem to be able to make the crashes happen.
P.S. Thank you for all you do...
evade
Hey Thanks for this new test realease !
however I still have some bug on the scatter animation.
I created a geometry with a native displacement effector controlled by an animated noise shader. In Vertex distribution mode it's moving correctly but in surface mode the scattered elements are shaking/vibrating/flickering.
I don't know if I did something wrong or if it's just a bug
Here is a testfile in attached.
testScatter.zip
Scatter-Animation-surface-issue-flickering
(155.78 KiB) Downloaded 411 times
Airpano
exist also a subscription version?
toms.ubnt
Airpano wrote:exist also a subscription version?
I have Subscriber version of 3.07-Test6a , and I actualy wanted to ask today, where the link went.
I downloaded it some time ago to test at home PC and today wanted to install it on my work PC and I wasnt able to find download link on the forum.
Subscription versions will not be at form of test versions anymore. We'll prepare VR builts when test period finished.
Tag12345
2 weeks or so of the .08 build, but nothing yet for c4d?
Tag12345 wrote:2 weeks or so of the .08 build, but nothing yet for c4d?
You're correct! Nothing yet, i'm working on!
Hi Tag12345,
please, be patient, 3.08 is not like any other SDK update, it’s a real game changer!
Ahmet is making a great work :)
Tag12345
I know I know!
Super excited top test many things I guess!
and eager for 3.09
Honestly, having the new OSL support, Eventually (hopefully) getting a better fog/volumetric light system and the Denoiser, are all many of us really need (as in can make alot more content that fits within Entertainment)
Rn most of us are in a loop
