Version 3.06.2 - obsolete stable
abstrax
zxctnt wrote:when i turn off the camera visibility ,shadow pass seems not the right result. :roll:
Thanks for the report. It will be fixed in the next release. The artifacts appear behind all transparent objects if emitters in the scene are partially shadowed and the shadow pass is enabled.
Steeviekay
I tested it now with different projects / for me its soooooo stable...awesome guys! Thanks :)
I would say this version is the best Ive ever worked with.
Weezer
Yep, Octane is really solid for me too.
I wondered - what's next on your to-do list? How far away are we from a version 3.1?
promity
Yep, panoramic won't work in 3.06.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
promity wrote:Yep, panoramic won't work in 3.06.
in which case? With motion blur + cylindirical pano?
fuchsundvogel
abstrax wrote: [*] "Expected exposure" of the adaptive sampling settings can now be set to 0, which disables the tweaking of the noise estimate, as described in the new features thread. This is also default now.
Happy rendering,
Your OTOY NZ Team
current default value in plugin is 1 instead of 0
promity
Cylindrical and spherical camera. No motion blur. But cubic panorama is working.
Lightwave 3d
It's working on me. But you need to change fovy to 90 degree. How could not you get it worked?
Kretschi
Spherical (fovx:360 / fovy:180 degree) is working in 3.06, but only without motionblur.
Cylindrical isn't working at all.
Kretschi wrote:Spherical (fovx:360 / fovy:180 degree) is working in 3.06, but only without motionblur.
Cylindirical need to change fovy=90 or less. It has changed on latest sdks.
