OctaneRender™ Standalone 3.06 TEST
funk
haze wrote:
funk wrote:There is some nice stuff in this update. Thank you!
I was wondering if you would consider an additional "simplified" triplanar texture. Right now you need to set up 3/6 image nodes with the correct projection, then plug those into the triplanar node. If I have a folder full of textures I want to quickly try out on my mesh, I have to click the load button on 3/6 different rgb image nodes and browse for the image 3/6 times.
I basically need box mapping, with blending to remove the seams. Maybe it could be a new projection type for images too?
In v-ray the triplanar texture is much easier to use. I just plug 1 texture in, and the triplanar controls everything else (scale, blend, offset, rotation). If I want more control, it also allows separate textures as an option.
The attachment vray_modo_triplanar.PNG is no longer available
Just so that I can make sure I understand correctly - would you mind sending me an orbx with the setup you are describing? Thanks :)
Sure, here's an example
oct306_triplanar.orbx
(1.41 MiB) Downloaded 288 times
I have 1 texture which is used on X, Y and Z, but has different uv transform / projection values to get the correct result.
+-X has planar mapping on the X axis (2 rgb image nodes)
+-Y has planar mapping on the Y axis (2 rgb image nodes)
+-Z has planar mapping on the Z axis (2 rgb image nodes)
NOTE: This example could be done with 3 rgb image nodes (1 for +-X, 1 for +-Y and 1 for +-Z), but this is what the modo plugin exports.
abstrax
Zay wrote:
Zay wrote:After releasing the Region Render I get a lot of crashes when using Adaptive sampling.
More info on this.
When the slave is running the Master will crash a lot when releasing the region render by clicking in the viewport. Even if you shut down the slave and restart the Master, the Master is now very easy to crash using region render. A full reboot is required to get a stable Master and a working region render tool.
Do you use the interactive render region or the render region in the film settings?
abstrax
Just for your information: I added the change log and started to add some images. More to follow tomorrow...
Vijay fixed a bug in the calculation of the error estimate which makes a big difference. -> I plan to get another test build out in the next couple of days.
Daniel_Ward
Hey guys,
great work on the adaptive sampling, it seems to work a treat. Just out of interest, is it possible to implement it with PMC?
Cheers, Dan.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
Zay
abstrax wrote:Do you use the interactive render region or the render region in the film settings?
I use the interactive render region where you draw a box.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 560.94| Modo/Blender/ZBrush/Daz/Poser
funk
I have been playing around with the triplanar texture a little more. I think the way it is implemented is going to cause problems for animated meshes.
1. This example uses a triplanar texture to do a manual box mapping, but with the seams blended out.
When you rotate the mesh, the textures "swim" through the mesh surface. I have made the X projection darker so its obvious that it always stays on 1 side of the mesh.
ORBX:
octane_306_rot_mesh_triplanar.orbx
(2.64 MiB) Downloaded 296 times
2. This second ORBX uses standard box mapping projection.
When the mesh is rotated, you can see the image map "sticks" to the surface and rotates along with the object correctly.
Nothing looks unusual. No screenshot is included because its hard to tell since I cant darken one side. You can see it clearly scrubbing the timeline in the ORBX file though.
I would like to see an additional simplified version of the triplanar texture that works just like box mapping, but with a blend angle parameter (similar to how V-ray does it below)
ORBX:
octane_306_rot_mesh_box_mapping.orbx
(2.63 MiB) Downloaded 291 times
3. The last example is from V-Ray's triplanar texture
You can see the darkened side rotates along with the mesh
In V-Ray, the triplanar texture sticks to the surface just like box mapping. Notice it also has a "reference space" option.
pegot
Can some one explain how to setup and use this new texture mapping? I downloaded funk's file but I can not find any specific way of connecting the six textures in the sample file. And the object in the scene just appears white.
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
funk
pegot wrote:Can some one explain how to setup and use this new texture mapping? I downloaded funk's file but I can not find any specific way of connecting the six textures in the sample file. And the object in the scene just appears white.
You need to load them in octane 3.06. Previous versions will not work. If you are not seeing a "triplanar" node, then you are on the wrong version
pegot
Yes I do have 3.06 test version - even had to update CUDA for it. And I seem to have all the other great new features. But I can't find the triplaner nodes. And the below screen shot is what it looks like for me when I open your file:
I'm on a Mac, by the way.
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
enricocerica
pegot wrote:Yes I do have 3.06 test version - even had to update CUDA for it. And I seem to have all the other great new features. But I can't find the triplaner nodes. And the below screen shot is what it looks like for me when I open your file:
Add a triplanar (texture/mapping/triplanar) texture and connect it to the diffuse node of the material. The triplanar node will provide six material node, just connect each of them to the textures.
Edit : You may use the blend angle to control the blend between each texture.
http://www.myline.be
