OctaneRender® pre-Beta 2.4 (win x64) [OBSOLETE]
Jaberwocky
My best Guess is use 2 emitters.1 set to zero and the other set to full opacity at the same X/Y/Z coordinates.
matej
Jaberwocky wrote:My best Guess is use 2 emitters.1 set to zero and the other set to full opacity at the same X/Y/Z coordinates.
Wouldn't that re-introduce the darkness?
cgmo.net
oguzbir
matej wrote: That's a semi-useful hack. And if you need to see the emitter?
That has to be corrected. Currently I thought that might help ones who are suffering.
From what I am currently testing,
In order to see the caustics passing through a specular material, that is lit with a emissive material you have to make the material not transparent. but to see the alpha shadow it has to be zeroed out..
So it is between the devil and deep sea :)
Hope to have the fix soon.
My Portfolio
infernoVFX
Hi everyone,
This 2.4 ver is slightly faster than 2.3 v5 (around 10% faster) on my gtx 580. I use 263.09 drivers, i didn't have any dark lines nor problems displaying actual number of cuda cores, so i guess this speed improvement is due to cuda 3.2 implementation (on my system 2.3 v5 is also using all 512 cores so there's no difference there....)
Here's some test images:
06:16 = 376 sec
05:42 = 342 sec
All the best,
Voja
Asus rampage III extreme, i7 950 OC 4GHz, Kingston 12GB DDR3, WD VelociRaptor 300gb, 2x WD Black 640gb, Asus ENGTX 580//
Gigabyte P67A UD7 B3, i7 2600K OC 5GHz! Mushkin Blackline 16GB DDR3, OCZ vertex3 SSD, WD black 1TB, MSI GTX 580 lightning OC 993MHz!
Proupin
lol still no file name and path in Octane render window title... well, next time
sublime
@matej:
Photoshop it..!!
lol
my humble spec: Quad Cores Q6600 @ 2.4 Ghz, 2GB, GeForce GTX 460 (x2), winXP 32 bit, 3DS MAx 2009
dadou351
Excellent build :D
The next version 2.5 --> displacement ? lol
good work !!!
msciwiarski
Octane 2.4 still has unexpected crashes when I try to manipulate with node connection in graph editor :(
cheers
Michal
Hardware: Core2Quad Q9650, Asus P5Q Deluxe, GeForce GTX580
Software: Windows 7 Ultimate x64, Sketchup 8, Blender 2.56, Octane 2.4
colorlabs
Great to see a release made!! Exciting new stuff!
Just a note, on my Palit 460 2GB I'm seeing a 12-21% speedup in pathtracing - 1.25 in benchmark to 1.41 w/alphashadows, 1.51 without. Not bad, but not I seem to remember a 50% increase was suggested :)
Mac OS X 10.8.0 | ASUS GTX 580 1.5GB | MSI GTX 470 | ATI Radeon 6870 | Core i7 2.9Ghz | 16GB
abstrax
oguzbir wrote:
Elvissuperstar007 wrote:luminescent materials do not pass through the alpha channel! ((
@Elvissuperstar007
I made it work man. :)
If you happen to make the opacity of the Emissive material to 0 (zero)
than you will see the alpha mapped shadow. :D
Its good to solve it without the need of a new release. :)
See below.
Thanks man! That gave us the actual hint, where the problem lies: The light is shadowing itself... That should be solvable.
Marcus
