There is nothing we can do. These are displacement limitations.DIO wrote:Displacement isn´t working in the mix material.
It works in the displacement slot directly in the mix material, but there is no effect when mixing materials
which have displacement on their own.
Also it doesn´t work putting a mix texture blending or masking with two displacement-maps into the displacement slot of a material.
No effect at all.
OctaneRender® for 3ds max® v2.0a
Hi karba
I found a bug with blackbody emmission : power change when movable proxy is enable or not.
- perro_abombao
Hi nildoe!!nildoe wrote:I Upgraded my licenses to 2.0, and now everytime i open the material browser to select a map/material im getting a plugin error "Missing Dlls Filename: octane3dsmax.dlr Class: SuperClass: 0xC10" , like octane is not properly installed..but after i click "Open" it seems to show all the materials and maps
win7 sp1 max14 sp3
Edit: Important to say that it happens only once per max session...
you correct this issue? I have the same problem now...
- spillstudios
any news for axyz anima material conversation? Its something I really need, if I have to switch to vray to render crowds it defeats the purpose.
dual xeon 128gb ram titan X + 2 x 1070
windows 10 - 3dsmax + Nuke
