OctaneRender 2 for Rhino (OBSOLETE)
v-cube
This may not be so easy. I could make all Octane specular materials have a bluish color in the RHino preview window - but customising the color on a case by case basis would not be easy.
For me a general 90 % transparency and a bluish color to represent a slight amount of sky reflection would be perfectly OK, this way we would be able to see that there "is" something ;)
Andreas
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
Hi Andreas - my understanding was that you wanted 50% transparency. ie.
Is there a possibility to derive the viewport material opacity e.g. from the grazing opacity value multiplied by 0,5? this way it would be possible to have a subtle representation of transparency for the viewport.
v-cube
Hello Paul,
sorry I think I was a bit unclear...
My initial wish was for my fake glossy glass material with the falloff map in the opacity which was opaque.
Since I thought that it would be a good thing if the viewport material somehow represents a certain degree of transparency which is derived from the octane glossy material, I suggested to take the value of the grazing reflection of the falloff map and multiply this by a number that seems appropriate e.g. 0,5. This way you would have ended up for a fake glossy material with a grazing value of lets say 0,7 multiplied by 0,5 with a transparency of 65 %.
Looking at it again, my suggested approach is maybe not ideal since the opacity falloff map is just used to create a certain degree of reflection (not opacity) on the material and the values I used in my approach are not really a true representation of the transparency.
So maybe the easiest (I really don't know if that is easy...) thing would be to add a subnode under the opacity note named "viewport opacity value" where the user could specify a rgb color which then would be used for the transparency of the viewport material (light colors -> more transparent, dark colors less transparent)
if that is not working maybe some switch like "make transparent" which simply puts the viewport material transparency to 85%.
This is IMHO another story as we are dealing with speculars materials here, right now all specular materials are 100% transparent in the viewport, no matter what values you key in the octane material (opacity, transmission...) while this is of course way better than the 100 % opaque of the fake glass, in practise when working on buildings you simply often don't know if there is a glass plane visible or not, so a little degree of opaqueness helps to visually identify the elements when modeling.
For specular materials my first thought was to use the opacity and/or transmission value to generate a transparency value for the viewport representation, however since I use 0% opacity a lot of times maybe it would be a better Idea to use the opacity value and add lets say 15% to this value so even if I would be using a 100% transparent octane material It would still be only 85% (100-15) in the viewport.
I hope I was able to make myself clear - english is not my native language sorry for that...
best regards
Andreas
v-cube
Hello Paul,
here is another suggestion:
I often find myself waiting (up to 10 seconds...) for the preview of the material in the material editor after I altered a value. While I observed that scaling the preview down helps, I wonder if there could be the possibility for the user to define a preview quality level to speed things up? I would guess the preview window is not connected to the render settings right? Just curious, Which approach is used to generate the preview (AO,diffuse, PT ...)?
best
Andreas
Hi Andreas - the material preview system is not ideal at the moment. I will investigate options to improve it after the next release.
Specular Materials : I have investigating the requests posted here. I have set the transparency of specular materials in the Rhino preview window to 80% - so you can still see the geometry. However I cannot see any option in the Rhino API to see a blue'ish color - since only a "Reflectivity" number can be assigned (not a color).
Glossy Materials : Setting a < 1.0 opacity in the Rhino preview window when you have an Octane Falloff map in the opacity pin is not really viable. I could make it that if there is "something" plugged into the Octane opacity, then the Rhino opacity would be 50%. Would that help your situation?
v-cube
Hello Paul,
thats great, thanks !
Thats also great, the blueishness is not really necessary/important.
yes, it would be great although I would prefer a opacity value of 20% (->Transparency = 80%) like your suggestion for the glossy materials, it is nicer looking and easier for modeling IMHO, since in 99% of all cases, the material will be some kind of glass.
Best regards
Andreas
v-cube
wish of the day :-)
-It would be great if the color correct modifier would incorporate a saturation slider and ideally 3 additional sliders for red green and blue power of the texture.
-If I create a "parent" material node e.g. by adding a color correction modifier on top of an existing rgb image node, the node should automatically be moved into the new subslot of the parent material, right now the slot is created empty and the old node is lost.
best regards
Andreas
v-cube
switching panel bug...
Hi Paul,
when switching from the material editor panel to the octane panel I often have a freeze of octane /rhino which forces me to brute force end the program...
best
Andreas
Andreas - is it possible Rhino/Octane is generating the preview when you change tabs, resulting in the freeze?
Return to “Rhinoceros 3D”
