When I pack a file, Octane makes a .ocp file, but the unpack feature is greyed in the File menu, and I can't unpack...
OctaneRender™ Standalone 1.27
I don't understand what you are speaking about...
- stratified
are you using 1.27? It shouldn't create an .ocp file in the first place, it's renamed to .orbx.ROUBAL wrote:I don't understand what you are speaking about...![]()
The unpack menu item is only enabled when there's actually a package loaded in Octane.
cheers,
Thomas
Thanks for your fast response. Damned... no, I was using 1.26 because I had understood that the packing feature was disabled in 1.27. Probably I misunderstood !
Well, I tried with 1.27 and I get the same thing except that the file format is .orbx :
The following error message when importing the orbx file :
Error during loading of OctaneRender macro:
XML error: OXa^octane_versionf1270000^octane_package_typef1
- stratified
You can use it but we don't recommend using it for your projects because we're aware of some outstanding bugs. We don't want anyone to loose any work.ROUBAL wrote:Damned... no, I am using 1.26 because I had understood that the packing feature was disabled in 1.27. Probably I misunderstood ! I will try 1.27 !
Thank you !
That's going to be fixed in 1.28, you should use "file > open" for the time being if you want to open a package.
cheers,
Thomas
