Ok,
please give me little time for fixing. I'll update asap with stabile version
Beta 0.68 (SDK 1.18 ) obsolete
- Subroutine49690
Hi Aoktar,
I also have a little problem with the 0.6.x
I converted hundrets of contentfiles (using the 0.3.x) for octane and designed materials for them.
Now with the new version I try to use my contents (also older scenes) and I get a C4D-crash.
Also material-preview cause a crash.
When deleting all materials in the scene and crate them new (using the 0.6.x), it works fine.
> It feels like an incompartibility between the materials from 0.3/0.5 to 0.6.
Another issue started with 0.5.x when using the preview for animation (NO full screen update). Randomly Octane-Plugin saves the same frame twice and overjumps the next frame.
For example I have a camera-motion frames 1, 2 ,3 are good...4 and 5 are the same (I watched the explorer > it saves twice the same png-files at the same time with different names (frame-number)...) frame 5 is overjumped (because the file already exists, but it is a copy of frame 4), 6 and 7 is the same file again, 7 does not render....and so on.
I tried many settings and variations but without finding a solution.
It's really important for me to get that problem fixed, because the scene is big and the voxelising/preparing needs about 5min ... but the sampling only 30sec.
I cloud not test it with the 0.6.x because of the material-problem I decribed before.
best regards, Chris
best regards, Chris
we are targetting this kind of problems on 0.6x series. Actually 0.67 is testing and i'll upload soon.Subroutine49690 wrote:Hi Aoktar,
best regards, Chris
For content material previews: can you give me a few samples for checking. On last versions, i have added some new mechanism to get correct previews. But data structure is same in all versions. I can give you a way to convert easily
Hi All,
I have updated the plugin to 0.6.7b. There is some bug workarounds and some conflicts with other plugins. Still has a character encoding problem. If you have non english Cinema4d directory name then we need to copy Libs64 files to main folder. We are working to fix this problem
yes, cameratag fov does nothing currently. ignore that and use camera fovcfrank78 wrote:FOV In Kamera does do nothing! I used one of the Testszenes! called SSS1.c4d Am i doing smthg wrong or is that a bug?
Kind regards Chris
Now, that the plugin seems to start up correctly again, I'm curious if there are still issues with the authentication using standalone and the plugin. Please let me know if they still exist.
Marcus
Marcus
