OctaneRender 3 for Modo [OBSOLETE]
MrFurious
Many thanks Paul look forward to giving this a test run. Toon Lights?? interesting.....
Dino Inglese
CG Artist
Melbourne Australia
Octane build 4.04.0.145
I have updated the TEST installers at the top of this thread with:
3.08.0.128
- Compiled with Octane 3.08 RC2
- Fixed bug where invisible Replicators would render after the first frame of an animation
- Shader Tree Image High Value is now used (together with the Diffuse Amount) to set the Octane Image power for Image nodes connected to Diffuse pins
- Resolved issue where if the Specular Map value was 0, it would render as a value of 1
There is an OSX build added to the installers, but the Linux build is not yet available.
funk
Thanks for the update Paul
Tharso
Thanks Paul for the new release...
rrbarb
...Caught Up to it...
Thank You Sir.
./rrb
Tharso
"After the first render is started (the scene data gets loaded), all subsequent renders will not reload the scene again and the render will start immediately. Only the objects that were changed will be reloaded, if any. If you want to force-reload them all (interactively) - use the "Reload" button of Maya's render view. Thus you only will experience the longer delay before rendering starts during the very first start of rendering session (if nothing significant was changed in the scene between sessions or course)."
We need this type of thing from Maya plugin.
I have updated the TEST build installers at the top of this thread with:
3.08.0.129
- Compiled with Octane 3.08 RC3
- Fixed issue where edited OSL Texture text was not being retained
* OSX version still crashing when importing an OBJ file on Modo11.2 onwards. This has been reported to Foundry
This would not be viable given the current way the Modo plugin works. When you close the Modo plugin viewport, the scene is removed from your graphics card, and changing this behavior would require a re-write of the major parts of the plugin.
Tharso
That`s not nice =( . this type of thing is so useful.
matrix2012
Please OctaneRender 3 for Modo Linux Version.
Return to “Foundry Modo”
