Cinema4D version 2021.1.1-R3 (Previous stable) 01.02.2022
19Nik90
aoktar wrote:3rd build(R3) is out for using. Enjoy it!
Hi Aoktar, both R23 and R25 doesn't start anymore with the latest version 2021.1.1.1-R3... R25 crash during initial loading.
Thank you
Thank you
what's R23 and R25 version numbers? It requires latest R25->25.117
19Nik90
Thank you
I have the latest version R25.117
hazenkind
Same here ..
no problems here with 2021.1.1-R3 in C4D R23 and R25.
Note that you always need to remove from the c4doctane folder, all the unnecessary c4doctane-RXX.cdl64/xdlib files not related with RXX specific version, and leave only one c4doctane-RXX.cdl64/xdlib file in ../plugins/c4doctane directory.
Please, share a screenshot that shows both the c4doctane directory opened, and the entire installation path, thanks.
ciao,
Beppe
There's not any change to cause this. As Bepeg4d said check your installation procedures. And send bugreport.zip if still continues after a correct setup.
19Nik90
aoktar wrote:There's not any change to cause this. As Bepeg4d said check your installation procedures. And send bugreport.zip if still continues after a correct setup.
I've done the usual installation procedure as always, attached my Cinema 4D Bug Report.
Thank you
BugReport.zip
Bug Report
(32.32 KiB) Downloaded 243 times
Thank you
Thanks! It doesn't show much information. What's your R25 version?
Find this location
c:\Users\USERNAME\AppData\Roaming\Maxon\Cinema4Dr25_12345678\_bugreports\octane
and send latest bugreport_20220201_xxxxxx.zip files.
19Nik90
Thank you
Find this location
Here's the Octane Bug report
Thank you
bugreport_20220201_122114.zip
Octane Bug report
(1.41 KiB) Downloaded 236 times
@19Nik90,
could you try with clean startup layout without having any Octane dialog?
