Octane X Beta Begins Now!
OddO
Goldorak wrote:No - 5XX cards don’t work. Apple metal drives for octane X only work on Vega and later.
So this means that the: Radeon Pro W5700X MPX Module for the MAC PRO 2019 doesn't work neither?
Regards.... and Thanks in advance.
OddO
AMD Radeon Pro W5700X is a 5XXX Navi GPU, already supported in both Catalina and Big Sur (it is the same for Vega GPUs).
https://www.techpowerup.com/gpu-specs/r ... 700x.c3583
On the other side, if you have a 580, so 5XX model, it is a Polaris GPUs, and you need latest Big Sur Apple Metal driver to be able to work with OctaneX.
https://www.techpowerup.com/gpu-specs/r ... -580.c2938
Happy Mac GPU rendering,
ciao Beppe
pixelis
Hie Beppe.
Does this mean Radeon Pro 560X should work under BigSur ?
ShaunMilShih
Hello, I'm using AMD Radeon Pro 580 with my iMac 2017 on Big Sur(11.0.1).
Do I also need to upgrade the driver? I'm a little confused with Pro 580 & RX 580.
timkeeling
Hi there, Has anyone with a Radeon Pro 560X GPU managed to get Octane working?
AMD 560X is a Polaris GPU, so it is supported by Apple Metal driver included in Mac Os 11.0.1 Big Sur:
https://www.techpowerup.com/gpu-specs/r ... 560x.c3193
Personally I have an AMD Radeon Pro 575, and it is working as expected under Big Sur.
ciao Beppe
timkeeling
bepeg4d wrote:AMD 560X is a Polaris GPU, so it is supported by Apple Metal driver included in Mac Os 11.0.1 Big Sur:
ciao Beppe
That's reassuring, thanks. Unfortunately I am still not getting a picture.
Here is a screenshot: https://imgur.com/Ubpw2th
This is Octane X PR3 from the Downloads section running on Big Sur 11.0.1 with Radeon Pro 560X GPU
It stil lsays "No render GPUs" under the render viewport
Am I missing something? Apologies!
timkeeling
This is a screenshot of Octane X PR5 (Big Sur) on C4D R23:
https://imgur.com/F7bjqkO
I went through all the demo scenes and couldn't get a picture unfortunately. Sorry if I'm missing something very obvious here...
timkeeling wrote:This is a screenshot of Octane X PR5 (Big Sur) on C4D R23:
Please go to c4d Settings/devices panel, and disable the Intel GPU, in order to render only with AMD Polaris GPU.
ciao Beppe
juyeonlee
Radeon Pro 5300M for the MAC PRO 2019 is working?
and I used c4d r20....
is it okay..?
