Test Version 3.07-Test3a
bratro
I just did download the new Cinema R19 Mac version and tried to install Octane according to the description. Unfortunately I can't make it work and I guess it is because there is no c4dOctane_R19.dylib in the mac download. But i figured, there is one available in the windows version. I hope this will be updated too ;-)
jeffbriant
Hey Ahmet, I've been using the plugin for a day and a half and it's working beautifully. REALLY nice job. Undo in the node editor is sooo nice. Network rendering works awesome too. I have a request though: would it be an easy addition to make the texture project path pop up when dragging maps into the node editor? it works when adding one to the Image texture node, but not when dragging a map directly into the node editor.
This would be super handy as the dragging feature is awesome when working with pbr maps :D. Often hand the project off to a colleague and then a bunch of stuff isn't in the tex folder.
Thanks again, back to work!
2x1080's network rendering to 4x980Ti's
zinogino
Noticed some issues with materials with an index of 1.
Yambo
jeffbriant wrote:Hey Ahmet, I've been using the plugin for a day and a half and it's working beautifully. REALLY nice job. Undo in the node editor is sooo nice. Network rendering works awesome too. I have a request though: would it be an easy addition to make the texture project path pop up when dragging maps into the node editor? it works when adding one to the Image texture node, but not when dragging a map directly into the node editor.
+1 for that!
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
bratro wrote:I just did download the new Cinema R19 Mac version and tried to install Octane according to the description. Unfortunately I can't make it work and I guess it is because there is no c4dOctane_R19.dylib in the mac download. But i figured, there is one available in the windows version. I hope this will be updated too ;-)
Yea that's correct. I'll try to build it for osx after a few laters.
zinogino
Just tried the SOLO texture function in the NODE EDITOR and it's great! One question tho, how to revert back to normal view in the IPR?
Studio21
zinogino wrote:Just tried the SOLO texture function in the NODE EDITOR and it's great! One question tho, how to revert back to normal view in the IPR?
+1i love it too! just right click in an empty space and choose "disable solo mode"
zinogino
Thanks mate, you're a saviour!
eyeonestudio
C4D Freezing : Node Editor - Delete Node - using "Del"Key
It is normal to disconnect the wire by dragging it with the mouse (the node still remains).
However, if you select a node and delete the node using the Del key, a problem arises.
Studio21
I had a few freeze ups with disconnecting wires as well. nothing i can reproduce consistently though
Best,
Guy
