Version 2.24.2-TEST6 - Test only
Gumz
aoktar wrote:
EDIT: I have found it. It's about embedded octane dialog. Will be fixed.
Sweet!
JavierVerdugo wrote:
aoktar wrote:
JavierVerdugo wrote:Aoktar maybe this is important.
I tried to install the plugin on cinema 4d 17. I downloaded the zip file, erase all the cdl64 except the R17 and the plugin didnt work. This time I erase all except R16 and the plugin works. Something wrong happens with c4dOctane-R17.cdl64 file.
Thanks for info. What's build/version numbers of R17?
Cinema 4D R17.016 (Build RB136011)
I have compiled with 17.032 sdk. Ex. When i compiled with 17.038's sdk, it can't run on 17.032. I'll ask for that.
useruser wrote:hi ahmet
thanks a lot for the new version! :)
it seems as if something goes wrong with R17 and the "template.l4d file.
i cant load any template to the prefs-folder an load it as default-template. octane crashes cinema imediately. when i delete the "template.l4d file in the prefs-folder:
C:\Users\Administrator\AppData\Roaming\MAXON\CINEMA 4D R17_8DE13DAD\prefs
then octane starts without any trouble.
i tried to create a fresh new template but whenever i save the template as "default template at startup" octane crashes while launching the octane-dialog.
it works without any trouble with v4d R14 so far.
thanks in advance! :)
my specs:
Win 7 64bit
c4d R17.032
octane standalone 2.24.2
It crashes when you have saved Octane Dialog to startup layout. Maybe same reason?
useruser
it crashes always whenever i modify the standardlayout. for example: i just have to open a pluginpalette and octane crashes while initializing the dialog-window.
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
useruser wrote:it crashes always whenever i modify the standardlayout. for example: i just have to open a pluginpalette and octane crashes while initializing the dialog-window.
can you post some bugreport.zip?
useruser
i am not shure if this bugreport is created during the octane-crash. i the mouse freezes and i have to quit c4d with the taskmanager
_BugReport.rar
(20.04 KiB) Downloaded 257 times
useruser wrote:i am not shure if this bugreport is created during the octane-crash. i the mouse freezes and i have to quit c4d with the taskmanager
_BugReport.rar
Not helpful. Can you describe the steps to produce crash? I don't know to use palettes.
useruser
i made a little screencast for you:
https://dl.dropboxusercontent.com/u/143 ... octane.mp4
miohn
anyone else having this?
In materials emission tab I cannot load a image-texture.
When I try to select it, it stays emty.
regards
Mike
miohn wrote:Hi,
regards
Mike
You can't. First create an emission texture later put any texture inside.
