Version 2.14.0 - TEST
kracher
aoktar wrote:
kracher wrote: hi Ahmet
i see right now it´s not a CUDA error but an OGL Error!
thanks for helping!
hmm, not a renderer error directly. But i see your free vram about 244mb. It's near to limits. try to decrease this usage.
Ahmet
NOW i have the reason for this issue:
Cinema crash (while octane render) when Photoshop is running at the same time.
When i close Photoshop everything works fine! :-)
arghh
kracher wrote:
i see righ now it´s not a CUDA error but an OGL Error!
thanks for helping!
Ahmet
arghh
yes, this is meanful. You are on low vram and pshop can use rest of. That's the why i say to all. Everytimes keep their eyes on free vram. Also use render instances as much as possible.
virtualzapp
can you give me scene to check? no need to textures and objects
yep here we go.
Thanks a lot.
Cheers
Regis
scene.zip
(87.14 KiB) Downloaded 205 times
VFX compositor / CG generalist
Mac Pro 12C 2.93GHz, 64gb ram, 1xGTX Titan X, 4xGTX Titans in Cubix
yep here we go.
Thanks a lot.
Cheers
Regis
at least to have all materials would be great ;) i liked to check your materials. I meant that no need textures of materials.
virtualzapp
aoktar wrote:
yep here we go.
Thanks a lot.
Cheers
Regis
Oops my bad, sorry for that.
Here we go with the materials ;o)
Cheers
Regis
scene.zip
(250.85 KiB) Downloaded 215 times
momade
Dean wrote:Something strange is happening with Alpha channel.
Text with Blackbody Emission illuminates objects in the background, and the alpha it sees almost transparent.
With Enviroment:
Without Enviroment:
hey dean
my guess is, that your text is so out of focus, that the camera lens blurr makes it transparent. its a typical behaviour like in real photography. could this be the reason? try to set your aperture to "0" for checkup.
br.
mo
milanm
Hi Ahmet
I don't know if this was mentioned before but i think i found a bug with how renderpasses are saved into folders.
I attached a scene along with render results. Instead of separated elements we get a combined multilayer file in each folder... but without layers so it can't be used :)
I noticed this with 2.14 and 2.12 on a mac version. Unfortunately I didn't have time to test on Windows yet.
Result of rendering Shading normals and Reflect Indirect:
test_SN0000.tif
PassesProblems.zip
(4.39 MiB) Downloaded 201 times
Edit: It appears to be a problem only when saving to TIFF. It's good to know for anyone else.
Regards
Milan
Colorist / VFX artist / Motion Designer
macOS - Windows 7 - Cinema 4D R19.068 - GTX1070TI - GTX780
Rafael-Vallaperde
Hey guys,
I can't download the new version , otoy forum asks me to login, but i am already logged in.
Weird
milanm wrote:Hi Ahmet
test_SN0000.tif
PassesProblems.zip
Regards
Milan
ok, thanks. It appears on only tif. Wll fix it on next versions
LudovicRouy
Thanks for c4d background, you did a great job once again ;)
