Thanks man,
I'll back to you tomorrow with those answers.
OctaneRender for Carrara 2.06.0051 [Test]
AnswersSighman wrote:Are you running close to your GPUs memory limits?
Are you seeing any errors in the log?
If you rebuild the scene does the background image come back?
I'm near the end of a development cycle and I have broken animations. As soon as I have fixed it I will release a new test version.
1.No. (I'm now working on a cut down scene to isolate why the background image is not shown rather than the full scene)
2. [08:25:47.509] Started logging on 30.09.14 09:25:47
[08:25:47.509]
[08:25:47.509] Flag Type Value Prefix Description
[08:25:47.509] ------------------------- ------- ---------- ---------- --------------------------------------------------------------------------------
[08:25:47.509] apiChangeMgr release 0 "apiChngMgr" Logs ApiChangeManager::update().
[08:25:47.509] apiNetwork release 0 "apiNetwork" Logs all important calls into ApiNetRenderManager
[08:25:47.509] apiNodeSystem release 0 "apiNodeSys" Logs all write operations in the API node system.
[08:25:47.509] apiProject release 0 "apiProject" Logs all important calls into ApiProjectManager.
[08:25:47.509] apiRender release 0 "apiRender" Logs all important calls into ApiRenderEngine.
[08:25:47.509] cudaProf release 0 "cudaProf" Enables general logging of CUDA profiling.
[08:25:47.509] cudaProfDetail release 0 "cudaProf" Enables logging of single CUDA activity records.
[08:25:47.509] heartbeat release 0 "network" Enables logging of the network rendering heartbeat.
[08:25:47.509] logAppendToFile release 0 "" If enabled, logging will be to the already existing log file appended
[08:25:47.509] logFlags release 1 "" If enabled, all log flags will be dumped during startup
[08:25:47.509] logForceFlush release 0 "" If enabled, every logged line will be flushed
[08:25:47.509] logJuce release 0 "JUCE" If enabled, JUCE logging will go through the logging framework of Octane
[08:25:47.509] logPrefix release 1 "" If enabled, each log line will have a prefix
[08:25:47.509] logTime release 1 "" If enabled, each log line will have a timestamp
[08:25:47.509] logToDebugConsole release 0 "" If enabled, logging will go to the debug console (Windows only)
[08:25:47.509] logToFile release 0 "" If enabled, logging will go to a log file
[08:25:47.509] logToStdout release 0 "" If enabled, logging will go to standard out
[08:25:47.509] netRender release 0 "netRender" General logging of network rendering
[08:25:47.509]
[08:25:47.509] OctaneRender version 2.06 (2060000)
[08:25:47.509]
[08:26:10.457] OctaneSceneManager::SetSceneDocument(000000002C63E5A4)
[08:26:10.675] Scene contents: 7781 primitives, 6 cameras, 1 lights
[08:26:22.422] OctaneSceneManager::RenderWindowOpened()
[08:26:23.467] OctaneSceneManager::LoadScene(000000002C5DFA9C)
[08:26:23.467] SetDepthOfField(dof=0.000000, autoFocus=1
[08:26:23.577] UpdateTexture - Unknown shader: Grass ['gras']
[08:26:23.592] UpdateTexture - Unknown shader: Grass ['gras']
[08:26:29.396] UpdateTexture - Unknown shader: Grass ['gras']
[08:28:59.702] Atmosphere
3. The background image comes back, it's just that EVERY time I try to animate it disappears again.
Steve
I've tried a couple of scenes with no luck repeating your issue. If you can, can you PM me your scene. Or you can wait till tomorrow and try the new release I'll be posting.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Are there any key frames on the background? Try removing them if there are.
Does the problem happen if you move the timeline from within Carrara?
Please try the following:
Find the octane_log_flags.txt file in the OctaneRender extension directory.
Enable the apiRender flag (remove the leading '-').
Open your scene, the ORVP, and the log window.
!!! Clear the contents of the log window.
From within Carrara single step the scene ONCE!
The log window should now be full of node change diagnostics. Please send it to me. If it is long please zip it and send it as an attachment.
Don't forget to disable the apiRender flag when you are done...
