Lightwave 3D Plugin v0.3
Make sure the OBJ Export propories is set to fast mode and untick "write uv" if you're not using any UV coords in your mesh.
							GTX260 Seven 64bit
I'm Superfrog
						I'm Superfrog
Thanks for the advice, I tried fast mode and it's really faster now!
Can you explain me what's the difference with this mode please?
I noticed that when an animation is rendered out, the frames are saved to disk as "image.lws1/2/3/4/".. is there a way to force saving as "image.lws_001/_002/_003/_004/" ?
Has you use de HC obj export or normal export?scratch33 wrote:Hi holocube,
Is the exporter broken in lw10?
Impossible to export a scene from lw10. The same scene works fine in 9.6
I have tryed with the 2 objects export optin (for HC and for win) bur nothing.
I7 920 12Gb GTX480
Q6600 4Gb GT9800
Q6600 8Gb GT8500
AMD X6 12Gb GTX275
AMD X6 8Gb
						Q6600 4Gb GT9800
Q6600 8Gb GT8500
AMD X6 12Gb GTX275
AMD X6 8Gb
Any errors?scratch33 wrote:Hi holocube,
GTX260 Seven 64bit
I'm Superfrog
						I'm Superfrog
could you share the scene?
could you just make sure you have the same settings in your octane exporter for both 9.6 and HC?
GTX260 Seven 64bit
I'm Superfrog
						I'm Superfrog
I'm exporting from lightwave 9.6 & 10 using the "octane obj win only + fast" settings and everything works almost perfectly except for 1 problem. All the polygons are flipped. I didnt realise it at first because octane appears to render all surfaces as double sided. Everything looks fine until you try making a surface an emitter (no light is produced).
I loaded the exported OBJ back into modeler and then I saw that all polygons were flipped. Octane seems to emit light in the direction of the surface normal and this causes a problem. If I flip polygons manually then use the exporter, it all works correctly.
Is it possible to fix this by making the exporter flip all the polys on export?
