OctaneRender 3 for Modo [OBSOLETE]
Uhlhorn
Thank You Paul, this is a huge help! :-) I actual have to render an animation.
yaseunghee
When i use vdb, i can't see and drag drop VDB Voxel's source channel in OctaneRender Layout. It can only Schematic Fusion Layout. And Volume's channels(particle source and voxel source) are too.
S/FLayout
S/FLayout
OctaneRenderLayout
OctaneRenderLayout
funk
yaseunghee wrote:When i use vdb, i can't see and drag drop VDB Voxel's source channel in OctaneRender Layout. It can only Schematic Fusion Layout. And Volume's channels(particle source and voxel source) are too.
click this
yaseunghee
Wow! Thanks funk.
And one more question.
Why smoke in octane render is dimmer than Modo's it?
When i saw a tutorial video, both Octane's and Modo's are rendered same alike.
But when i render my vdb files in modo with octane, it looks vague.
my image
my image
tut image
tut image
If you use a VDBVoxel item in Modo, the plugin will read the number of grids from the first frame (which in the example you are using is a small number). So if you have an animated VDB which changes in size throughout the animation, you are better off using a Mesh Item OCS/ORBX proxy containing the VDB sequence than the Modo VDBVoxel item.
yaseunghee
Wow! Thanks Paul.
But..another question..
How can i render animation?
i tried it, but i didn't get fire images but cube(proxy) images only.
when i render frame by frame, i got a normal fire image. However rendering it start to end all at once, i got only cubes(proxy mesh).
To solve it, What setting should i do?
Tharso
how can I render deformed mesh in octane?
It should render automatically. Can you send me a scene with a deformed mesh which is not rendering pls?
What version of the plugin are you using pls?
Tharso
It render automatically. My fault .
Thx
yoshikai
Hi Paul.
Thank you for update latest version.
Octain is really fast render plugin.
Well, I ask some question.
I can't change to projection Type in Environment Texture.
I Think only light probe is works.
but, I can see the change projection type button.
This button is always deactivate. I can't touch this button.
and Environment texture is not working with sequential file.
I want to use 2 environment map.
1 HDR map (projection type light prob)
2 sequential file(projection type camera projection)(live action image).
Would you please tell me How to use 2 diffarent environment map?
I already tested choose type of visible environment and lighting environment.
but, It's not works.(actually It' works,but light prob and camera mapping(sequential)is not works)
sincerly
Return to “Foundry Modo”
