Stabile version 1.01 (SDK 1.20.3) **** 17.01.14 ****
bepeg4d wrote:
aoktar wrote:SVITAdmin, can you try with previous liboctane.dylib/octane.dat files?
this works for me, thanks ;)
i have copied only the r15 lib and changed the name as before and bring back the previous .dat and it works just fine.
anyway, if you could create three different zip files for the three versions, it would be better, five minute of your work but a lot less headache for all the users ;)
ok, i'm trying to save some space
SVITAdmin
Thanks. This worked for me.
So using the previous DAT file is OK? We are in fact using the real 1.0 even with the old DAT file?
Just confirming :)
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
TBA3D_70
Works fine now :) Thanks!
A small note:
If I click on "license agreement" in the Octane dialog --> the pop up window can´t close.
Only with forcing restart C4D -> it will close !
Also:
The numeric entering of numbers don´t work perfectly in the settings dialog!
If I type a number into the fields and press enter --> only the slider won´t update ??!!
Thanks for your hard work and good support, again, Ahmet!
Best regards,
Thomas
TBA3D_70: thanks, i'll try to fix these on other version which is based on new sdk. Because, plugin is completely changing internally and turning back is not elegant for me.
Sdk 1.20.3 and 1.20 is very similar, except a bug fix for R15/Win8. I'll check 1.20.3 for Macos soon
TBA3D_70
Thanks for updating this in future versions :)
The numeric entering with the missing slider update don´t work only in the settings dialog!
If I do this in the camera tag (and enable the camera imager) --> slider-update is working fine with numerical entering :)
small notice: the whole "help"tab menu in the octane dialog isn´t working on mac
Best regards,
Thomas
could someone test this version please? it's for Macos, and ok for me.
http://render.otoy.com/customerdownload ... acosx2.zip
SVITAdmin
aoktar wrote:Hi,
brilliant. works for me. Thanks!
TBA3D_70
Yes, I can confirm this.
This version works as it comes :)
Thanks for quick support, as usual !
Best regards,
Thomas
creativebloke
yep all good here too :D
twitter = creativebloke
EditRoom
Works in R15 when I remove the R13 and R14 dll. Great!
