OctaneRender® for 3ds max® v2025.4 - 16.10
coilbook
Can we get more controls for AO engine? Like shadow color, sunlight color if we want it more vibrant and yellow, etc. I think rendering animation in path-tracing mode with GPUs is still not easy or fast.
Elvissuperstar007
Movable proxy
I always turn it on. I tried all the modes, it doesn't work, although it worked before.
octane 2024.1.2
Elvissuperstar007
coilbook wrote: Tue Nov 25, 2025 3:32 am Can we get more controls for AO engine? Like shadow color, sunlight color if we want it more vibrant and yellow, etc. I think rendering animation in path-tracing mode with GPUs is still not easy or fast.
paride4331
Elvissuperstar007 wrote: Tue Nov 25, 2025 8:20 am Movable proxy
octane 2024.1.2
Hi Elvissuperstar007,
That’s strange, it seems to be working on my end.
Could it be a scale issue?
Regards
Paride
Elvissuperstar007
Your TurboSmooth has Iterations = 1 — that’s why the model is smoothed in the viewport.
Set Iterations = 0.
Leave Render Iters at 2, 3 or 4 — whatever you prefer.
Result: low-poly cage in viewport, fully smoothed mesh only on render.
Last edited by Elvissuperstar007 on Wed Nov 26, 2025 8:41 am, edited 1 time in total.
coilbook
Hi Paride,
Can you please look at the file attached. For some reason octane is not rendering flames? VDB was made in embergen. Thank you
Here is another file with temp exported and it looks like minecraft
vdb bug.rar
(713.97 KiB) Downloaded 95 times
PS Embergen used to render nicely but not it's a mess and renders blocks. How can we recreate good flames like in embergen? Could you please recreate the same flame as embergen using VDB i attached? Thank you!
minceraft flames.rar
(2.08 MiB) Downloaded 97 times
vdb with temp.zip
(2.1 MiB) Downloaded 93 times
coilbook
After many attempts and messing with channel this is what I have but it doesn't have this depth and flame contrast. How can I make it look like in embergen? Could you look at the scene. Maybe I am missing something. Octane doesn't have this contrast like embergen .
It's like embergen I can see inside flames and see crisp fire edge.
Thank you!
fixed example.zip
(2.15 MiB) Downloaded 91 times
paride4331
coilbook wrote: Mon Nov 17, 2025 9:38 pm There is a bug with motion blur.
The camera is attached to the moving sphere, but the sphere is getting motion blur as if it were passing by a stationary camera.
The scene is attached.
It should be the opposite — the background should have motion blur because both the camera and the sphere are moving.
Can this be fixed ASAP?
Hi coilbook,
This will be fixed in the next release (16.11).
Regards
Paride
coilbook
There is a bug with octane volume. If you shift copy it it will say no vdb found even though vdb path is there
