Cinema4D version 2020.2.5-R3 (Obsolete stable) 16.09.2021
Delizade
When I tried to download the latest version I got this?:
"The file you requested does not exist.
Please contact [email protected]"
Kalua
davidyannick_1 wrote:But just after installing it I can't see any difference ?
I see it a bit different for the right side icons, but I agree there could be some more contrast with the left side icons.
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
It's more than a bit. There's not much room to make darker, it's becoming irritating with black icons.
You may give a try for advice.
Kalua
Then why not make all lighter like the right side icons?
That is to me the most logical solution for now.
Regards,
Kalua wrote: Then why not make all lighter like the right side icons?
Regards,
I think it's the only way. I'm a bit conservative to keep our style, but it's not good for dark interface.
Kalua
I don't know if this is exclusive to latest version:
When I copy a branch of nodes from the Octane node editor (materials), pasted structure is ok but the images nodes come along with a different file path and file name... how come? Is it a bug?
Regards,
Pasted images nodes come with different files and paths.
Kalua wrote:I don't know if this is exclusive to latest version:
Regards,
There's not any changes on latest versions. I don't know any bug like that but I can check it if you give enough details to reproduce it.
Kalua
Regards,
Hard to reproduce it. Happened twice already, different projects. I reach you in case I have some more reliable info.
thanulee
Instance color and multiinstances doesnt work in this version. I cant get the color out of cloner while multi instances. Can u see if this is the case there too? thanks
thanulee wrote:Hi,
How did you try? It's working, no reason or changes to cause this.
