Cinema 4D version 2020.1-XB2-R2 (EXPERIMENTAL) 10.01.2020
SSmolak wrote:There is still bug with cloner related to "one instance". Last time cloner didn't displayed first instance. Now cloner doesn't display instance if it count is set to one :)
Assume you mean "multi-instance". What's the reason of using it for one clone?
SSmolak
Generally there is no reason - I only report that I saw. Another thing is that in R21 Cloner Instance ( Instance Object ) is buggy when it is set to Instance Mode = Multi-Instance. Object is dissapear from viewport. Viewport mode doesn't work. I will report this to Maxon. This is why I temporary wanted to use Cloner as one-instance cloner.
nejck
Could be important for animating growth and similar things perhaps :) I'm not doing it that myself often but it did strike me as something that people would do with it.
VVG
Thanks for Volume examples 2020.1-XB2-R2
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
Mysterium
Hi !
I have a material - universal - with "Image Tiles" nodes plugged into some channels. Each time a project is closed and then opened, the Image Tiles stop working and I have to create new ones and all re-setup these new Image Tiles nodes so that they work again.
Λrtist • Director • Designer
[1]2920X - 64GB RAM - 4*RTX 2080TI
[2]1950X - 64GB RAM - 4*GTX 1080TI
Mysterium wrote:Hi !
OK, would you mind to share example project to show it? Also did you try on different scene with a different setup?
Mysterium
I tested on different machines, and in multiple scenes and it's the same problem.
EDIT 1: Rather than recreating the nodes, I can also fix the problem by cutting and pasting the names of the textures in the files field of the ImageTiles.
I have to do it with the live viewer on before re-rendering each scene otherwise it is not taken in the final rendering.
EXEMPLES_TILES_BUG.zip
(50.22 MiB) Downloaded 415 times
smessing
Hey Aoktar,
I have R21.115 with Octane Enterprise 2020.1 XB2, Nvidia 441.66 studio driver, 4x 2080ti cards showing up correctly.
My problem is that the RTX switch in the device settings is now greyed out. I cannot turn it on. Is there something I am missing here?
EDIT: Clean reinstall of the 441.66 driver fixed my issue
-Steve
desire
Just closing the Cinema 4D after Live Viewer have started
Win10 x64, studio driver 431.86
c4doctanelog.txt
(4.59 KiB) Downloaded 411 times
prod_insert crush.zip
(33.94 MiB) Downloaded 483 times
Hi desire,
please perform a clean installation of Nvidia 441.66 Studio driver:
https://www.nvidia.com/download/driverR ... 5646/en-us
To perform a clean installation, please follow these steps:
ciao Beppe
