OctaneRender™ 2019.1.1
abstrax
Elvissuperstar007 wrote:the render worked at night, then it didn’t work anymore
octane render 3ds max 2018.1 2019.1 1019 .1.1
NVIDIA 1080 GTX 8gb 64 GB DDR 3 CPU memory 6Gb
nvidia 436.48
users with a regular V4 license 2018-2019
https://www.dropbox.com/s/q8mo8u8eblheg ... R.rar?dl=0
The download link is not complete unfortunately. If you want, you can send it to me via PM instead.
nejck
J.C wrote:New edges rounding has shading errors compared to eg. Cycles implementation.
This faceted look happens on all types of meshes.
I can confirm this behavior with the C4D plugin based on the version 2019.1.1 :) Round edges in general unfortunately appear to be broken and don't "round out" even simple cube shapes. Probably something went all weird in the code somewhere :)
abstrax
Zay wrote:AI up-sampling still fails on win7 for me. It will render to the end and then all GPUs fail.
Started logging on 27.09.19 09:19:25
OctaneRender Enterprise 2019.1.1 (6000101)
Up-sampling error: CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered
Small (non-)update: We can reproduce the problem on all Win 7 computers we've got, but haven't found any issues in our code yet. We will continue to try to find a solution, but this will take a bit longer than expected, i.e. 2019.1.2 won't have this fixed unfortunately.
Elvissuperstar007
dasmodular
No Octane slave installed on Win 10 with OctaneRender_Enterprise_2019_1_1_win.exe
Now there are separated installers for Slave daemon:
I have made the same mistake at first download :D
ciao Beppe
Elvissuperstar007
I even remodeled the building, it’s worth adding material, it stops rendering
Elvissuperstar007
Started logging on 06.10.19 13:11:51
OctaneRender 2019.1 (6000100)
Tried to access pin via an invalid ID P_ALBEDO (409)
Tried to access null node pin
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
J.C
When auto bump is enabled in Vertex displacement it produces unwanted shading pattern.
System – Windows 11
flamingox
Hi, Octane Team,
Octane Render is best gpu render, excellent is for unreal engine but please integrate bake system for unreal
Best Regards
