The download link is not complete unfortunately. If you want, you can send it to me via PM instead.Elvissuperstar007 wrote:the render worked at night, then it didn’t work anymore
octane render 3ds max 2018.1 2019.1 1019 .1.1
NVIDIA 1080 GTX 8gb 64 GB DDR 3 CPU memory 6Gb
nvidia 436.48
users with a regular V4 license 2018-2019
https://www.dropbox.com/s/q8mo8u8eblheg ... R.rar?dl=0
OctaneRender™ 2019.1.1
I can confirm this behavior with the C4D plugin based on the version 2019.1.1J.C wrote:New edges rounding has shading errors compared to eg. Cycles implementation.
This faceted look happens on all types of meshes.
Small (non-)update: We can reproduce the problem on all Win 7 computers we've got, but haven't found any issues in our code yet. We will continue to try to find a solution, but this will take a bit longer than expected, i.e. 2019.1.2 won't have this fixed unfortunately.Zay wrote:AI up-sampling still fails on win7 for me. It will render to the end and then all GPUs fail.
Started logging on 27.09.19 09:19:25
OctaneRender Enterprise 2019.1.1 (6000101)
Up-sampling error: CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered
- Elvissuperstar007
- Contact:
- dasmodular
No Octane slave installed on Win 10 with OctaneRender_Enterprise_2019_1_1_win.exe
Now there are separated installers for Slave daemon:
ciao Beppe
I have made the same mistake at first download
ciao Beppe
- Elvissuperstar007
- Contact:
I even remodeled the building, it’s worth adding material, it stops rendering
- Elvissuperstar007
- Contact:
Started logging on 06.10.19 13:11:51
OctaneRender 2019.1 (6000100)
Tried to access pin via an invalid ID P_ALBEDO (409)
Tried to access null node pin
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
Empty file name.
When auto bump is enabled in Vertex displacement it produces unwanted shading pattern.
System – Windows 11
System – Windows 11
