Cinema 4D version 2019.1-XB2-Test1 (Experimental test ver.)
nejck
aoktar wrote:
nejck wrote: Still doesn't work on my end :\
What's version number? Checked latest package, it's working on me.
You Sir have just been PMed! :)
cirasa
in displacement vertex it is possible to deactivate the smooth subdivision?
tnx
cirasa wrote:in displacement vertex it is possible to deactivate the smooth subdivision?
tnx
Set subdivision level to 0?
cirasa
tnx
subdivision bilinear it's possible? deactivate only smooth
cirasa wrote: subdivision bilinear it's possible? deactivate only smooth
Which parameter are we talking about? We can just have what the renderer(as you can see in standalone) offers us!
cirasa
ok thanks, i make the request for the standalone version
Iceman9
Aoktar, how does one access thin wall material option feature?
chrisfranklin6002
Same as Felix - obviously RTX is what everyone wants.... Love you though Ahmet xcxc
sethRichardson
aoktar wrote:
miohn wrote:o.k. then in Gods name: 2019.1-XB2-Test1-Experimental-Test-Version
Where do I plug-in the "RoundEdges" Pin?
regards
Mike
This is a bug. It only exists on the diffuse material.
If you start out with a glossy material the pin won't be there. You have to activate the pin in diffuse mode then attach rounded edges to it and swap to glossy or another material type to actually use it or even see the pin.
Might want to take a closer look here.
regards
Mike
Having a bug not surprising but I don't see anything like you said. Round edge is hidden by default. How do you create material?
