Version 3.08.4 (obsolete stable)
thanulee
zoppo wrote:From the manual:
Also, make sure your object is closed or thick when using Mediums. In single sided objects, mediums will not work.
Fyi they do work. Even planes with irregularities work. But as u wish :P
TonyBoy
They evidently do work if you don't mind a few artifacts.
tomsvfx
Hi Aoktar!
Is there some ETA of this cinema4d build with 3.08.5 standalone version?
viewtopic.php?f=24&t=69127
tomsvfx wrote:Hi Aoktar!
Hi tomsvfx! Don't have ETA, why did you ask?
tomsvfx
This version contains one critical Standalone bug fix that our team is waiting and requesting for some time already. And I hav noticed other memebers have reported this issue under C4D versions.
viewtopic.php?p=347350#p347350
In 3.08.5 this issue has been fixed.
Cinema4D wise, I havent spotted anything that would be critical, now im only waiting for Cinema4D version that contains latest Standalone version with the fixed bugs.
If you could update Cinema4D version with latest Standalone update, I would be very thankfull for that.
Tom
tomsvfx wrote:This version contains one critical Standalone bug fix that our team is waiting and requesting for some time already. And I hav noticed other memebers have reported this issue under C4D versions.
Tom
I have some work to complete. Drop me PM if you wish to don't wait. So I'll send you a private build for 3.08.5
aybekdes
Hello Ahmet,
The problem with small lights is still exists.
Is it because of units, Im working in millimeters
https://monosnap.com/direct/0VYnV5Q5ogF ... vW5Fcv51Kv
Scene attached
smallLights.c4d.zip
(82.43 KiB) Downloaded 348 times
bratro
Hi!
Just a little bug in Cinema 4D R20 Mac, but when I have a spline (also when it's converted) and add the Octane tag with Hair activated, the live viewer doesn't update the position of the spline when I move it. I have to restart the live viewer and then it's ok, but when I move it again, nothing happens ;-(
If it has been reported already, please ignore it ;-)
tomsvfx
Hi Aoktar, when do you plan to release 3.08.5 for C4D?
BCres
Noticed this morning that the "Get region from LV" in the Region Render settings isn't responding and remains at 0% for all entries. This used to work great everytime for me.
Doesn't work whether using the LV region or the Film region. In the middle of project and can't switch to 3.08.5 to see if it's been corrected.
Thanks.
