Hi Octane Team,
Can you please give me explanation how to properly use Light IDs which were introduced in v4?
There are a lot of options inside Kernel tab and OctaneObjectProperties, so it is confusing how to use them
Or we should expect tutorial only when "Stable" version of V4 will be released?
Cheers
OctaneRender® for 3ds max® v4.00-RC4 - 6.07 [OBSOLETE]
- SergKlyosov
Win 10 64 | RTX 3090 | i9 9980XE | 64GB RAM
- paride4331
Yes sure,SergKlyosov wrote:Hi Octane Team,
Cheers
I have already planned a tutorial about this but there are still some issues I preferred to wait. I'm just checking 3dsMax plugin 6.08 and just released I will post Light ID tutorials too.
Regards
Paride
There is a bug with GPU failures.
If I have 2 3ds max windows opened and one is done rendering then I steal slaves for the other max scene to render I get GPU failure during denoising. I guess denosiing GPU gets clogged from the first 3ds max rendering and there is not enough memory for the second. PC must be restarted
denoiserThread2 : Not enough free memory to run the denoiser. Required memory 475501728.00 MB
- senorpablo
Tutorials are great. However, I wish that Otoy would invest time into improving the documentation. That's kind of the point of it; to have a central place of collected knowledge and reference. Rather than having to go on a research scavenger hunt to find obscure bits of information. It would be great to add examples into the documentation.paride4331 wrote:Yes sure,SergKlyosov wrote:Hi Octane Team,
Cheers
Regards
Paride
This is one example where the documentation is extremely poor: under the Blackbody Emission, this is the explanation of Distribution:
And that's basically worthless. I goes into zero detail about HOW it actually works. It might as well say: "the distribution controls the distribution."Distribution – The distribution controls the pattern of the light. This can be set to an Image (Greyscale/RGB) so that an image texture or IES file can be loaded, the orientation or direction of the light is then adjusted through the image texture’s projection map.
When will there be new version?
RC6 just got released for stand-alone. We are a bit behind.
PURE3D Visualisierungen
- paride4331
Hi mbetke,mbetke wrote:When will there be new version?RC6 just got released for stand-alone. We are a bit behind.
I'm testing RC5, it should be released asap.
Regards
Paride
Light Bug:
There is a window plane in front of the light.Light is switched off but still visible.
I think screenshot is pretty self explaining.
Disclaimer: I use 3.07 but in my experience so far with bug fixing I think this applies here too.
- kcpr-raffaEl
- Contact:
I think it's related with "visible in reflection/refraction".mbetke wrote:Light Bug:
I've got the same when reflection of invisible light is visible in mirror.
But it's only in V4.
The checkboxes are greyed out there for object properties. So I can't change this.
- paride4331
Hi coilbook,coilbook wrote:There is a bug with GPU failures.
this issue should be fixed in RC 6 SDK
Regards
Paride
