Version 4 - XB3-R1 (Experimental)
eyeonestudio wrote:When "Octane Settings-Camra Imager" is used, Multi-Pass Buttons appear.
But "Camera Tag- Camera Imager-Denoise"is used, it does not appear.
You have to enable Camera Imager also.
thanulee
Hi, i get a render failure in live viewer after denoiser. See image.
Btw, denoiser is making my image brighter.
Also insta crash when adding multicloner.
edit: also cant render sequence at all with R18, see my post at latest stable too plz. Here doesnt crash yet* just freezes on first frame seems to load forever
thanulee wrote:Hi, i get a render failure in live viewer after denoiser. See image.
It has crashes with multicloner. I'll add new fixed build soon.
You need to use tonemapped buffer for passes if you need denoised pass at same as LV. Don't forget that LV is tonemapped, passes are linear by default.
thanulee
Thanks mate, im on it! keep up the good work!
aybekdes
Custom LUT is not working, please see video below
https://monosnap.com/file/bH2sYgYS4M1zn ... zkOpQ1bMLW
3.08 - WORKING
3.08 R1 - not working
3.08 R2 - not working
Or am I doing something wrong?
aybekdes wrote:Custom LUT is not working, please see video below
3.08 - WORKING
It's working as i could see. And I cannot see your link
1- http://www.aoktar.com/octane/index.html ... mager.html
2- http://www.aoktar.com/octane/index.html ... stTAB.html
aybekdes
Can you see video below?
https://monosnap.com/file/bH2sYgYS4M1zne4PRqDRzkOpQ1bMLW
or upload to youtube?
cyartist
Hi Aoktar
You did not include in the latest installer the version for R16
NC17z
"It's a render pass and color profile is like what you set in render settings. Linear by default, so you see like that. Please apply gamma correction or just switch to tonemapped as in Live Viewer."
This does not answer my original question of how to export only one pass using the Ai Denoiser. Can anyone explain how to just export the Beauty Pass with the Ai Denoiser applied. Animated Sequence. A .tiff not Layered. I just want one image not a layered image.
Thank you in advance for any assistance in this matter,
Lenny
pxlntwrk
NC17z wrote:Can anyone explain how to just export the Beauty Pass with the Ai Denoiser applied. Animated Sequence. A .tiff not Layered. I just want one image not a layered image.
Lenny
pxlntwrk.net
