OctaneRender® for 3ds max® v3.06 TEST 3 - 4.31 [OBSOLETE]
solomonfl
neonZorglub wrote:Plugin's version string consists of two parts - version of Octane core integrated into this version of plugin, and the version of the plugin itself.
This is a TEST release with new features implemented, so some issues are expected. Please report the bugs in the "Bug reports" section.
Changes of the 4.31 version, from 4.30
  • Updated Octane Renderer to 3.06 TEST 3
  • Added Adaptive sample support
  • Added Texture types : AddTex, Subtract, Compare, Triplanar, Ridged Fractal
    viewtopic.php?f=24&t=58640
Wohoooo!!!!!! Thank you so much neonZorglub for bringing us update so we too can enjoy 3.06 for Max.
I am totally loving Adaptive sampling, I am noticing almost a 50% reduction in render time for most of my scenes!! I didn't realize what an impact this would have ~ I am even daring to use 3.06 in production :) Thanks again!!!! Today is a good day
Elvissuperstar007
Do not ask right now, I know that a lot of work, it would be great in the future to get the panel most needed!
In this panel should be: Mobile proxy, Phoenix fd - Fume FX, Self-light shader conversion, Scale correction, Shader converter (Corona.vray.autocad-revite.fstorm.),Remove noise parameters ( Ready-made presets, animation-statics),Materials (gloss, reflecting, diffusion ,,,, and so on))
I will remind you of this in the future!
platon11109
My English is bad! Google translator to help me!
Intel Core i7-960 3.2GHz | GTX460 2G| GTX 580 3G | 24gb ram | Win10 64 |
mbetke
I have a scene which renders fine in 4.30 but not in 4.31.
It stops after one sample and only one of four GPUs are active. But not rendering, only the little timer (render time) counts up and up. The extended error log says nothing.
How can I share the file with you guys to elaborate the error? It has several licensed assets and graps assets from different places all over my workstation.
PURE3D Visualisierungen
Goldisart
confirm two mistakes 1. freezing the renderer (after this error even when you restart 3dmax - this error remains in the scene) 2. error starting https://youtu.be/piuUoMuOb9Y
usually, this occurs when you configure adaptive rendering during active imaging - test 3dmax 2017
I can't go on video because it happens according to my feelings spontaneously - if I find an error be sure to show the video
very waiting 4.32 TEST
mbetke
Ahh I see Goldisart. Got the same "active viewport" issue with my aboove mentioned scene.
acc24ex
Elvissuperstar007 wrote:Do not ask right now, I know that a lot of work, it would be great in the future to get the panel most needed!
you can do most of them via maxscript, you can check out my script thing in the signature, you have a "To movable proxy button" at least, and I have at least some basic setting to create glossy diffuse specular from wirecolor rgb, and convert between them.. it could be made so it switches between other materials, it's open for editing
ramone163
New SHADOWS pass not working. In Octane SA 3.06 Test 4 works fine.
GPU: 2x4090; 3ds max;
Behance portfolio; Handmadefont.com;
kcpr-raffaEl
mbetke wrote:I have a scene which renders fine in 4.30 but not in 4.31.
I can confirm this error - it appear especially with higher resolutions.
For me temporary workaround is to switch to "Noise" layer in Octane Viewport. Then render starts to work correctly.
This error doesn't affect regular rendering in my case - only Octane Live View.
Can you confirm it?
coilbook
what expected exposure should be set to if under camera exposure is set to 6. Should i change it to 6?
