OctaneRender™ Standalone 2.12.1
ssokol
For me "inline node preview" is always black (plane or sphere) in material tab.
Is it error?
coilbook
Thanks.
Any eta on 100% static noise where if I render 200 samples and it is grainy the grain does not move at all like a still?
Tugpsx
Thanks for update
kavorka
One thing we just noticed, in batch render, if you leave the filename blank it allows you to render everything but it just doesnt save the images. Should probably have it come up with an error instead of letting you render.
abstrax
kavorka wrote:One thing we just noticed, in batch render, if you leave the filename blank it allows you to render everything but it just doesnt save the images. Should probably have it come up with an error instead of letting you render.
That's a feature not a bug. It's the same with the other animation scripts. This way you can test render the stuff without having to save it.
00Ghz
You're holding it wrong :D
HDRI Editor for Blender : Your own HDRI Studio at an affordable price.
https://gum.co/HDRIEditor
manalokos
We us the batch render ignores the check boxes and renders all nodes.
abstrax
Just a heads up: We released another small bug-fix build which should fix the issues reported for version 2.12.
Apologies for the noise.
Zay
(Network rendering) Is there any way to pick up the slave if the connection is dropped for a split second?
When I see this happen and the master lose the slave, the master will not see the slave again even if the slave is running. I have to close and restart the slave before the master pick it up again.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
stratified
manalokos wrote:We us the batch render ignores the check boxes and renders all nodes.
Sounds like a bug, we will check it.
cheers,
Thomas
