OctaneRender™ Standalone 2.11.1
Sakalakapaka
It's a pity, that you can not reproduce that issue :(
I noticed that it isn't dependent on the scene. This is some kind of interface bug in the 2.1xx version. Even without any scene loaded, when I tried to click "Daylight animation", "Render imported animation" or "Turnable animation", Octane crashes immediately. I attached the crash log.
Windows 7 64 bit PL, Nvidia GTX 580 3GB, driver version 337.88.
Crash log PL.txt
(870 Bytes) Downloaded 213 times
English is not my native language.
]Intel Core i7 4790K, 2 x Nvidia Geforce GTX 780 Ti SLI, 32GB ram, NEC SpectraView 242, Windows 7 x64
abstrax
After some testing Shakalakapaka found the reason why it's crashing on his system, but wasn't on ours: The script directory (File -> Preferences... -> Application -> Script Directory) wasn't set and caused Octane to crash.
To work around the problem, you have to set the directory to an existing, close Octane and open it again. After that the scripts should work again.
Of course, it shouldn't crash if that option is empty and we will fix it with the next release.
BroAugustine
It seems like LUA is broken, at least on Win 64. To test the simplest scene, I use a sphere hooked to and render target. Each script I try crashes when closing the script with either 'exit' or clicking the X (window's close button).
Here's the crash for the noise-generator.lua (version .11). Open the script, click 'Export' then X (window's close button), crash.
Problem signature:
  Problem Event Name:	APPCRASH
  Application Name:	octane.exe
  Application Version:	2.11.0.1
  Application Timestamp:	5435d917
  Fault Module Name:	octane.exe
  Fault Module Version:	2.11.0.1
  Fault Module Timestamp:	5435d917
  Exception Code:	c0000005
  Exception Offset:	0000000000457ba4
  OS Version:	6.1.7601.2.1.0.256.48
  Locale ID:	1033
  Additional Information 1:	a61b
  Additional Information 2:	a61b3bb44475be528bedcfa2a8c8f5c8
  Additional Information 3:	5edb
  Additional Information 4:	5edba160ea229b79087658b88c661c2c
Same with turntableG.lua (Version 1.02).
Don't even need to load a scene. Just open the script and the dialog appears saying 'no render target selected'. Click 'Ok'. Crash.
Problem signature:
  Locale ID:	1033
Same happens with Ol Ready Cam.lua, etc.
Win 7 64 | I7-2600K 3.7 GHz | GTX 460, GTX 760 / Driver 347.09 | Cuda 7.0.18
Zay
Bug: Network rendering in different Clay Modes can create "ghost" renders.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 560.94| Modo/Blender/ZBrush/Daz/Poser
mykola1985
nice.... tested some complex scenes! no bugs so far ;)
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
abstrax
BroAugustine wrote:It seems like LUA is broken, at least on Win 64. To test the simplest scene, I use a sphere hooked to and render target. Each script I try crashes when closing the script with either 'exit' or clicking the X (window's close button).
Just have a look at the post above: http://render.otoy.com/forum/viewtopic. ... 43#p206743
ratata
Hello,
Very nice additions, the only issue I found is that PMC kernel doesn't render (any scene, even empty), this is what I get in log:
OctaneRender version 2.11.1 (2110002)
PMC kernel: Unsupported compute model (52)
device 0: PMC failed
Win 7 64bit, GTX 980
http://www.twitter.com/sandidolsak
6850k|64gb|4 x GTX980ti
abstrax
ratata wrote:Hello,
Next week I will look into the new Maxwell GPUs.
grimm
abstrax wrote: Next week I will look into the new Maxwell GPUs.
It's no problem if you would need a tester Abstrax. I don't have it right now but I will have a 980 next week so I can test.
Jason
BroAugustine
Abstrax,
My scripts directory is properly set. Still, Octane crashes when the above mentioned scripts are closed or exited. I even tried the Octane Windows 32 bit version and it does the same thing. These crashes also occurred in version 2.10.
