Error writeing texture
- fivebythree
- Contact:
Hello, might I suggest watching my quick video on this matter - figured it was easier show than explain how I was able to overcome this bug. Made with Version: 0.13.82 - and that is key. The latest updates aren't stable enough for use in daily work. https://youtu.be/vSXhSg0zqB4
STANDALONE+STUDIO WIN11PRO | RTX3090 | XEON 4210 20 CORE | 96GBRam
hi fivebythree
so the trick is to create a octane material from sketchup material or?
thanks
edit
hmm can't find the 0.13.82 version - only 0.13.87 :-/
thanks
edit
hi
i'm having this error for almost one year now - could this be fixed, so i can set the temp folder by myself?
i't annoing that simple material creating in skecthup is not possible.
as you can se the folder does exist (see attached image).
but in my system it is named:
\\tmsrv1\users$\brj\Octane\SketchUp\temp\su_textures
the path sketchup uses is:
////tmsrv1/users$/brj/octane/sketchup/temp/su_textures/
this gives an error
I have tried to test the paths with my file manager (servant salamander)
if i paste "\\tmsrv1\users$\brj\octane\sketchup\temp\su_textures\" into my file manager the folder is found
if i paste "//tmsrv1/users$/brj/octane/sketchup/temp/su_textures/" into my file manager the folder is found
if i paste "////tmsrv1/users$/brj/octane/sketchup/temp/su_textures/" into my file manager the folder is not found
so this seems to be the problem? "////tmsrv1/users$/brj/octane/sketchup/temp/su_textures/"
could this somehow be fixed or tested?
thanks
jorgensen
this gives an error
thanks
jorgensen
- Attachments
- path.JPG (16.19 KiB) Viewed 5480 times
