Here is a resulting animation. I attached one of the ships to the camera and made it do a crazy roll...
Steve
Smooth & Easy Camera Animation for OR Standalone, ORC v1.21
- AlexKotovKn
a camera that focuses on the chest of the player character would be nice if anyone can make it
the default camera is not good enough due to free running lvls
- Attachments
- 73.gif (7.43 KiB) Viewed 18373 times
- ff7darkcloud
It doesn't work anymore with Octane Render 3.0
( PC ) Win10 x64 | 2xRTX2080TI | ASUS Rampage VI Extreme | i9-7900x | 32GB | 1600W
( Laptop ) Win10 x64 | RTX2080Max-Q | Lenovo Legion Y740 | i7-9750H | 32GB - Octane Standalone Win 10/ Sketchup 2019
PORTFOLIO: https://renderspace.wixsite.com/portfolio
- ff7darkcloud
Hi Roeland thanks for your reply, I tried again with 3 alpha 3, when I select output directory or hit render nothing happens. Maybe the plugin needs some kind of overhaul for Version 3? Any help would be greatly appreciated!!
This is an example of what I use this for: https://www.youtube.com/watch?v=4haRGGKqUmQ
I think the problem is that a while ago we standardized all the enumeration tables to be members of the
To manipulate paths use the functions in the
You may get the project path and file name as follows:
Finally note that the `string.gsub` function searches for a pattern, a pattern matching any extension of 3 or 4 characters is
Roeland
octane table. So the constants to specify file formats are octane.imageSaveType.PNG8 etc.To manipulate paths use the functions in the
octane.file table: octane.file.join(path, ...) will join paths together and it will correctly handle the case where any of the paths happens to be an absolute path. It will also handle the different kinds of slashes. octane.file.getFileNameWithoutExtension will strip the file extension, at the moment the script will overwrite the project file when you have an ORBX package open.You may get the project path and file name as follows:
local sceneFile = octane.project.getCurrentProject()
local projectPath = octane.file.getParentDirectory(sceneFile)
local projectName = octane.file.getFileNameWithoutExtension(sceneFile) .. ".orc"
local orcFile = octane.file.join(projectPath, projectName)
[[%.%w%w%w%w?$]].--
Roeland
