OctaneRender® for 3ds max® v2.0a
mykola1985
turbosmooth render iterations don't work. Karba, please fix that! in 1.5 it was working like a charm!
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
Dom74
mykola1985 wrote:turbosmooth render iterations don't work. Karba, please fix that! in 1.5 it was working like a charm!
It works, but if you change iteration value, you must close and re-open the Octane viewport to render it.
Win7 x64 - 3DSMAX 2019 - 32GB RAM - 1080 TI
acc24ex
Ibon_83 wrote:
sun fireflies go back. :( this will be fixed?
Please, fix this as soon as posible. Octane is becoming better and better in some aspects, but this kind of problems are simply unacceptable. Now I can render moving objects, displaced geometry and a lot of good things, but all of this are useless if I can´t render a simple exterior without having fireflies everywhere.
Project deadlines are killing me and I have to call for it again: Please, fix this as soon as you can Karba
did you try setting caustic blur to something higher than 0 - I think that worked with fireflies, maybe all the way up
visionmaster2
turbosmooth render iteration dont work for me too.
Karba
visionmaster2 wrote:turbosmooth render iteration dont work for me too.
Have you checked "use object render settings"?
coilbook
same here turbo sooth render does not work i thought it was me does something wrong
mykola1985
SOrry Karba, just forgot about that!!! :mrgreen: checking ''use object render settings'' solves the problem!
MistAjuliax
Hi guys,
it doesn't work for me too. I have 3ds max 2014 and render iteration in turbosmooth dosen't update in realtime in octane viewport render. Is ti normal or a bug ?
Win 10 pro 64 / GTX 1070ti, gtx 1070 / FX8320E / 16Go DRR4
visionmaster2
thank you Karba, it works now.
mykola1985
MistAjuliax wrote:Hi guys,
it's ''under development''! ;)
Return to “Autodesk 3Ds Max”
