I've had a similar problem and found out that the newest version of the plugin (or Blender?) is language - sensitive in a way... Try to avoid any not-english characters in your texture names. Some of my textures had names containing polish characters like "ś", "ż" etc. and they wouldn't render unless I renamed them (changed ś to s, ż to z and so on).Marten74 wrote: I just got the most insane problem in the middle of a production... Finally got the latest version to work. I´m unwrapping a plane, adding a texture... And to my big surprize I can see it correctly in material mode, but not in rendered mode!!! I can´t see the texture in view port rendering or final rendering. I thought maybe it had something to do with image format because I had a grass texture that would work as it should, but nothing else did. I tried different texture formats and ratios etc with no success. I then thought maybe it is the blender version, but in cycles it works perfectly. I then reverted to the 2.69 octane render version, and my simple tests in it worked just as it should. I can even (thanks god) open the 2.70 scene i´ve been working on in the 2.69 version and it renders my material setup perfectly. What happened??? Since my material setup works opened up in 2.69 (and also a similar material setup in cycles 2.70) I can only draw the conclusion something really strange is going on here. Any one else experiencing this problem? It´s a show stopper...
Cheers, Szymon
