OctaneRender® for Poser (Windows) 1.55 [TEST] - OBSOLETE
ok i deleted everything out of the scen and it works fine. what does this mean
Did you try ticking the Motion Blur button? You could also try changing the "Allow scale cameras" in the config. If you send me the simplest scene which demonstrates this problem I will take a closer look.
spartan00j
okay my scene is big but i can send it through mediafire link. plau im getting this message now
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\ViewportForm.py", line 909, in on_timer
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\lib\site-packages\wx-2.9.1-msw\wx\_core.py", line 16237, in __getattr__
raise PyDeadObjectError(self.attrStr % self._name)
wx._core.PyDeadObjectError: The C++ part of the ViewportForm object has been deleted, attribute access no longer allowed.
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
spartan00j
here you go Paul [link removed]
the camera only animate when im not refreshing geometry
Win 11
128GB RAM
RTX 3060 TI
This is fixed in the next release. It happens if cancelling the animation by closing the Viewport.
If I open the scene you posted and click "Render Animation", the camera moves through the scene. It looks OK to me.
spartan00j
yes it moves in view port but the exported photo's, the camera not moving.
Win 11
128GB RAM
RTX 3060 TI
If I open the scene you posted and render the animation, it renders to png, with each png having the camera moved slightly each frame. So it appears to be working correctly.
spartan00j
okay i solved the problem. I started a new scene and exported the rendertarget. then i open the one i was working on and imported that rendertarget i just saved. so Is there a setting in the rendertarget that would stop the camera from animating.
Win 11
128GB RAM
RTX 3060 TI
I would have thought if there was a rendertarget issue - I would get it too when rendering that scene. I cannot think of any rendertarget setting that would stop the camera from animating - sorry. I cannot explain this - but good to hear you have a workaround.
Ken1171
face_off wrote:The plugin should use the normals from Poser - so whatever smoothing you have set in Poser should come through to the plugin. You can also override this in the Configuration. Notes from 1.23.0.11....
# - Added configuration option to force Octane to calculate the normals for the entire scene. This is partially implemented, and 0 = use Poser normals, and <> 0 = use the smoothing angle set in Octane Standalone
Hi Paul,
The reason why my Octane renders were ending up with some objects faceted was because the Octane plugin's "smooth" option in the respective materials was set to "false". I have done some testing, and the Poser smoothing settings for the particular models have no effect on this setting. So whenever something renders faceted in Octane, I have to go through the all the materials one-by-one and change the "smooth" setting to "true".
You said there is a configuration option to set this globally, but I could not find it in the plugin, the OctaneDefaults.py, and in the plugin's PDF documentation. I have searched the PDF for "Poser Normals", or just "normals", and I only found the "smooth" option for the individual materials. Where can I find the option that affects the global smoothing settings?
Return to “Poser”
