OctaneRender® for Poser (Windows) 1.50 [STABLE] - OBSOLETE
If I want to edit a material and switch to material mix, both materials are diffuse.
If I want to change one of them to something else, the following error shows up:
I have had a few reports of this error and am working on it. I will post back here once I have more info.
I think I have been able to fix this. Can you pls try the version in the TEST thread (http://render.otoy.com/forum/viewtopic. ... 13#p182613) 1.52.0.28, and let me know if it resolves your problem.
ArminBeier
Just installed and tested it.
edit:
When I do something like selecting material mix, I can at least change the diffuse nodes. But there are a lot of nodes like bump, normal etc, which are not connected and I can't change these.
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 1471, in <lambda>
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\SetupForm.py", line 1780, in comboBoxNodeType_SelectedIndexChanged
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 445, in ChangeNodeType
TypeError: hex() argument can't be converted to hex
when I load older material settings, I can edit them, but it seems that the new created standart settings for a new node (diffuse, glossy, etc) is making these problems
There may be a problem with the names.
When I load a material, where there is a greyscale value to 0 (so it doesn't affect anything), I can click on "Disconect", it switches it's name to "Not connected", also in the list the name changed.
I can still change it to anything else.
But if I copy that material with this now "not connected" node, and paste it to another object, I can't change the "Not connected" node again.
OS: Win7 x64
CPU: i7-4770 @3,40GHz
Mainboard: Z87-Deluxe
GPU: 2x GTX980 Ti Hybrid
RAM: 32GB
HD: 250GB SSD
I can you pls install 1.52.0.29 - the latest release, which resolves this issue.
ArminBeier
Seems to work again now. Thanks
OS: Win7 x64
RAM: 32GB
HD: 250GB SSD
harlequin3d
Occasional, non-repeatable crash. Always crashes when Octane is rendering. Cuda.Log was empty (0kb w/ no text) so I didn't upload that.
Windows 7 64bit
Ram 24GB
GTX 780 Ti-3072MB/GTX 470-1280MB
Nvidia Geforce 335.23 driver version
Poser Version: 10.03.26510
Octane Plugin version 1.50
config.xml
(1.01 KiB) Downloaded 310 times
octaneplugin.log
(455.98 KiB) Downloaded 282 times
It is incredibly rare for Poser to crash whilst rendering in Octane. The only reason I can think of is that one of your rendering cards has failed, or has overheated. Have you tried monitoring your card temperatures with GPU-Z?
harlequin3d
Yeah your right. Throttled down the video cards so they don't run quiet as hot and everything seems fine now. Thanks!
What are the most important stats of a video card in regards to Octane rendering speed, Cuda cores, clock speed, fill rate...?
I'm the wrong person to ask on this - but probably cores (but you cannot compare number of core between the 500 and 600 series for example. There is a "benchmark" thread comparing the cards somewhere on this forum which might help too.
spartan00j
hey Paul is there a way to set all node to diffuse at once. Or do i have to do them one by one.
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
Return to “Poser”
