OctaneRender™ Standalone 1.21
abstrax
pixelrush wrote:When opening the Octane benchmark scene for the first time I note that there are some node inspector values that are not showing their default value and need to be set.
When you load old files only those pins are populated that existed in the version the file was written. All other pins that were added in later versions are left empty. It's a design decision we can still change fairly easily. So if everybody disagrees, let us know.
There is a kind of strange option available in Camera/Scale of View and other places which allows for choosing Sun Direction. Is this correct? :roll:
Well the sun direction node calculates a float value which can be connected with a float pin. There was some hackery to not display it for float pins, but display it for others. We removed it and always show it.
Post processing broken/missing? perhaps not had to enable at bottom of Render Target list first... ;)
See above: That pin didn't exist before and so is not populated.
probably old one - Background colour of notes is a shade of choice but not WYSIWYG.
I don't understand it, could you please explain?
abstrax
Elvissuperstar007 wrote: does not operate, requires OBJ
You either drag&drop the file into Octane or you create a scene node (Geometry -> Scene) and then select the Alembic file in the file chooser.
abstrax
Seekerfinder wrote:
abstrax wrote: We also replaced the image texture transformations described in the update with a generic projection system, that supports now linear, spherical, cylindrical, perspective, box and UV mapping.
THAT'S what I'm talking about!! Finally... thanks guys!
Feature request (belly laugh, I know...) - would be great if one had the option to lock S.X & S.Y. This could be useful for other texture mapping nodes as well.
Seeker
That's on our to-do list.
RayTracey wrote:Hi all,
I've uploaded an Alembic igid body physics animation with camera path to demonstrate how camera motion blur and rigid body animation works in Octane. Instructions are provided in the note.
Enjoy!
P.S. Alembic file import is still a work in progress and materials should be easier to modify in the next iteration.
no need for obj, the alembic provided is enough ;)
thanks sam for sharing :)
RayTracey
Enjoy!
Thanks beppe, good to know it works.
roeland
FrankPooleFloating wrote:Grouping and Ungrouping (which rocks), did cause a couple crashes (while rendering - did not if paused)... But wow, what a feature!
Do you remember what nodes you were grouping or ungrouping? Was it geometry only? Was it connected to some render target?
Roeland
Elvissuperstar007
Why removed these useful functions?
I'm not a programmer. I am not able to work with C + + and Lua
abstrax
Elvissuperstar007 wrote:Why removed these useful functions?
They are temporarily disabled. We will bring them back.
Elvissuperstar007
fuhhh it perfectly! ))
and how to run the animation? render
abstrax
Elvissuperstar007 wrote:fuhhh it perfectly! ))
Not done yet. As I said in the opening post: All the animation stuff is work in progress and will be completed over the coming releases.
