Roadmap
Moderator: BK
i can only say that i have not given up working on it. so i spend as much time as i can to get done what needs to be done, but i won't release something until 99.9% of the past problems are sorted out. as i've stated earlier this means writing lots of parts nearly from scratch, to get rid of insufficient code. or in other words: i haven't come that far to let this thing pass away in shame. definitely not.3dmania wrote:Yeah,
I have nearly given up hope on a update. Still have the crashes and waiting desperately for material import and export
that this wasn't the plan (of course) is another thing, but for some reason it is just necessary.
ps: i'm nearly done with the nge and general node display and will give a short update around today evening...
so here some info about the most noticeable fixes and features for the nge/node display:
- strangenesses with selections when clicking nodes (or due to deletes, mat unlinking, ...)
- external value nodes correctly inherit min/max values
- drag&drop access to other materials/used nodes (= no need to switch mats and use copy&paste)
- pins now show also if there is an internal node (by being painted full/empty - just like in the standalone)
- problems with completely disconnected nodes (causing problems on load)
- problems with syncing values/structure updates between nge and main mat tab
- problems with transformation nodes (transform/rotation/scale)
- problems when the root node (= mesh pin) is disconnected and the material gets unlinked at the same time (this was one reason for subsequent link problems in the main mat tab)
plus image preview for materials and single nodes - the latter with life updates when changing values:note: the idea behind placing the preview directly underneath a selected node is, that it saves scrolling and clicks vs. having it expandable somewhere in the editing pane (it moves with the node btw). it also allows to quickly click through a chain of nodes and immediately see how they affect each other. finally (imo) such a preview usually serves as a rather rough control for things like overall color, contrast, saturation, inversion, etc.; thus it shouldn't hurt if it isn't 100% visible all the time. let's see how it works out in practical editing...
Well... I see just one problem with it... And that is that it is not released yet
Looking forward to it... the constantly unlinking materials sometimes leading to a crash are giving me headaches.
Birdovous
Master: Core i7 2600K, 32GB RAM, 2x EVGA GTX Titan X (SC)
Slave 1: Core i5 4460, 16GB RAM, 2x EVGA GTX 1080 Ti SC2
Slave 2: Core i7 9700K, 64GB RAM, 2x ASUS RTX 2080 Ti
- linvanchene
edited and removed by user
- Spectralis
I fully endorse your animation update proposals. I use animation a lot and while Octane his improved my renders a great deal I would still like to have more control over cameras and lighting.linvanchene wrote:My basic wishes for the next update is that after all this waiting:
Absolute Top Priority and desperately (!!!) needed:
- I will be able to keyframe important Octane Paramters of the camera like focus, focal length and exposure in animations
Would help a lot to improve the quality of scenes:
- There maybe will be a smart focus tracking solution like "always focus on the right eye" for animations
- I will be able to keyframe light emitting materials to produce scenes with flickering or color changing lights in animations.
- I will be able to use volumetric light
Well that is just my wishlist as a heads up what is expected after all this waiting.
No pressure at all...
Update / Edit:
Added priorities to give an indication of importance
To put it different:
- Not being able to save materials not being able to merge scenes are inconveniant but I can work around it.
BUT
- I cannot work around missing features that are needed to create animations and higher quality scenes that are just not included at all
ASUS Maximus VI Extreme, i7 3770k, 32GB RAM, 4 x GTX760 4GB, Win 8.1 x64.
