OctaneRender® for 3ds max® v1.11a[Test]
Karba
oguzbir wrote:
Karba wrote: Can I have your scene?
[email protected]
Just sent the scene you via wetransfer.
I hope you find it.
Unfortunately I can't reproduce any crashes. I played for 10 minutes by moving vertexes and pressing the update button.
JulioCayetano
I also have problems when reloading the geometry in Octane's viewport. Not always but quite often, when I press the reload button 3D max is crashing.
This bug is really annoying, I have to save my scene every 5 min if I don't wanna loose my work.
Thanks for your attention. I hope this could be fixed for next release.
MoBo: Gigabyte X58A-UD3R // CPU: i7-930 // RAM: Kingston 12gb DDR3 // Display GPU: GTX 480 1,5gb + Rendering only GPU: Gigabyte GTX 670 4gb.
Karba
JulioCayetano wrote:I also have problems when reloading the geometry in Octane's viewport. Not always but quite often, when I press the reload button 3D max is crashing.
Are you using dirt texture?
JulioCayetano
Yes I do, to create a "painted metal" shader, (if I remember well) I use a mix of a dirt diffuse and a bluish glossy.
Hope this will help.
Karba
JulioCayetano wrote:Yes I do, to create a "painted metal" shader, (if I remember well) I use a mix of a dirt diffuse and a bluish glossy.
There is some bug with dirt in material preview which can lead to crash
HHbomb
nobody find ao of transparent material too dark ?
[email protected]
I'm not using it, and I have this problem
Windows 10 64bit, Intel i5, 32gb Ram, 2x nvidia 1080ti, Driver: 390.77
gueoct
HHbomb wrote:nobody find ao of transparent material too dark ?
Isn´t it in the nature of all Direct Light modes, that they don´t take into account transparent shadows?
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
HHbomb
"fake shadows" do...
Return to “Autodesk 3Ds Max”
