OctaneRender™ Standalone v1.03 (obsolete)
kavorka
here is my log from my GPU failure. (Mentioned previously)
hitting the restart render button does nothing. I can close my other Octane windows, but it still shows this same amount of VRAM from other applications. If I then open a new Octane instance that requires less VRAM, that one is fine, but this one won't be able to get the GPU that failed to start working again unless I close and re-open.
Started logging on 22.01.13 09:08:51
CUDA error 2 on device 0: The API was unable to allocate enough memory to perform the requested operation.
-> Failed to allocated device memory
-> Failed to launch kernel (pt)
CUDA device 0: Path tracing failed
CUDA error 2 on device 1: The API was unable to allocate enough memory to perform the requested operation.
CUDA device 1: Path tracing failed
-> Failed to allocate device array
CUDA device 0: Failed to reallocate data texture 22 of context 0
kavorka
If I grab a material from the LiveDB that has a float input to control the scale of various textures, I am unable to modify the amount. If I click on a texture and change the input from float1 to float2 and then back, I can then use the main float input to control everything, correctly. This is not just from 1.03, I noticed this a while ago.
manalokos
This version of Octane sometimes freezes permanently when I refresh a model.
Does anyone else experienced this problem?
Refracty
Marcus,
can you let us know if the use of a "background image / image plane" in the viewport for alignment purposes will be possible in the upcomming release.
This is especially useful since the shadow catcher was introduced...
abstrax
Refracty wrote:Marcus,
There won't be any new features until stable 1.1. We will probably release another version this week with some bug fixes and then next week 1.1. After that we will continue with new development releases with new stuff. It's not done yet (we are all working on other things at the moment), but it shouldn't be too hard to do and so it might become available soon after 1.1.
Marcus
Refracty
thank you marcus for the update :)
ROUBAL
Great news ! I asked for this feature so many times ! :)
abstrax
kavorka wrote:every scene I load with 1.03 (I export from Blender each time) ends up showing an error in the loading area. After everything is loaded, it will still show that it is loading something. Sometimes my mesh, sometimes a texture. Seems to be purely graphical because everything works fine, even what it says is "loading".
I just opened up this same scene with 1.0 (without exporting again from Blender) and the problem persists. I haven't had this problem before 1.3 (that I know of)
I tried several times, exporting from C4D or loading directly in Octane, but I can't reproduce this issue. Any idea how we can reproduce it? Doesn't it run the voxelization after loading? It should display "Compiling mesh..." in the status bar then.
Marcus
andrear
Many thanks to the whole staff for the 1.1 compute cards support.
The new build work smooth as never before.
Only one more thing to say,
it is dramatically difficult to stop to play with it!
Andrea
MSi GE75 Raider 8SF - W10PRO - RTX 2070 8GB mobile
kavorka
Marcus
I had it show compiling mesh once after, but it didnt show the loading bar, just a kinda messed up looking "compiling mesh". Maybe my install is messed up somehow.
