Batch Render -- different issues?
SamQior wrote:On a smaller note - the plugin version seems to render slower than the stand alone has anybody else noticed this or is it just an issue with my setup :?
Just increase the "Refresh Time" in Octane settings. The smaller this value, the more times per second the plugin locks the image buffer from Octane engine, preventing engine from rendering. Set the value to 1 or 3 seconds, and it will render faster.
SamQior
Thanks Very Much JimStar!!!!
Intel i7-3930 4.5 ghz(Overclocked)/ Dual GTX 690 4GB + GTX 650 Ti 2GB/ 32GB Ram/
Intel i7-3770k 4.2Ghz /Dual GTX 780 Ti 3GB /32GB Ram
RealSpace
v1.02b does not fix the issue for me. Batch render works on 1 of 2 machines I have octane on. Very similar specs between the two computers.
Ian Clark
RealSpace
http://www.realspace3d.com/
SamQior
Ok 10 minutes a go the problem came back!!! decided to uninstalled the plugin then re-installed it, then in the Plugin preference I switched off auto load. This seems to have done the trick I still don't understand why its so problematic - see if that helps anyways :?
fbb
i still got some batch render problems (almost for 3 month now). i always switched back to other renderers when it occurred but i still want to use octane for some jobs but as long as these problems keep popping up i think it's to risky for me.
so i tried to render a kind of big scene from a project i recently did (about 4mill polys, first i wanted to do the whole thing in octane but when the batch problems keep popping up i switched back to vray because at that point it was the savest thing to do).
it at first all goes fine until it stops at a random point. i switched verbose mode on to track it down and thats the lat thing my machine logged .
1:40 Setting Mesh data of general mesh
****************************** GENERAL MESH DATA ******************************
Number of vertices: 4000268
Number of normals: 10747666
Number of UVs: 5871195
Number of polygons: 3940976
Number of material indices: 3940976
Number of vertex indices: 12495782
Number of normal indices: 12495782
Number of UV indices: 12495782
1:40 ...done setting Mesh data in 0:00
1:40 Voxelizing...
Result: //fbbblue/INS_MOSCOW/production/sequence/Dev/model/maya/work.je/scenes/station_cameramatch_v16_octaneBatchtest__2452.ma
Fatal Error. Attempting to save in C:/Users/JOHANN~1.ENZ/AppData/Local/Temp/johannes.enzinger.20130204.1904.ma
// Maya exited with status 1
whats weird is, that it had already rendered about 20 frames without complaining. anyone knows what can cause this problem? like i already said, i like octane and it's speed but at the current state it feels to unstable for me to use in a real production (or at least batch rendering does).
fbb
fbb
Can you please post here the dumps Maya creates after crash?
Maya creates them in Temp directory, the files looks like (numbers will be different):
MayaCrashLog130110.0621.dmp
MayaCrashLog130110.0621.log
I need both these files to investigate the reason of it...
And if you can give me the scene which causes this error - it may be helpful too.
fbb
shure. crash log says:
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0x46A12D34
Fault address: 1BA21F14 in C:\Program Files\Autodesk\Maya2012\bin\octane.dll
0001:00430F14 Logical offset (see .map file for location)
Call stack:
(0) section:offset Address Frame
0001:00430F14 0x1BA21F14 0x00C2C6D0
Module: C:\Program Files\Autodesk\Maya2012\bin\octane.dll (-exported-)
Decl: public: static class Octane::NullEmission * ptr64 Octane::NullEmission::create(void)
(1) section:offset Address Frame
0001:00431198 0x1BA22198 0x00C2C880
(2) section:offset Address Frame
0001:00431198 0x1BA22198 0x00C2CA30
(3) section:offset Address Frame
0001:00431198 0x1BA22198 0x00C2CBE0
(4) section:offset Address Frame
0001:0055EE9C 0x1BB4FE9C 0x00C2CCC0
Decl: public: static class Octane::ObjectMesh * ptr64 Octane::ObjectMesh::create(void)
(5) section:offset Address Frame
0001:00407687 0x1B9F8687 0x00C2CEB0
(6) section:offset Address Frame
0001:0046F835 0x1BA60835 0x00C2D3B0
(7) section:offset Address Frame
0001:004753D1 0x1BA663D1 0x00C2D430
(8) section:offset Address Frame
0001:000A0453 0xEB5F1453 0x00C2D4E0
Module: C:\Program Files\Autodesk\Maya2012\bin\plug-ins\OctanePlugin.mll (-exported-)
Decl: initializePlugin
(9) section:offset Address Frame
0001:00036D6A 0xEB587D6A 0x00C2D560
(10) section:offset Address Frame
0001:00037A7F 0xEB588A7F 0x00C2D890
(11) section:offset Address Frame
0001:00038A23 0xEB589A23 0x00C2DAD0
(12) section:offset Address Frame
0001:00039179 0xEB58A179 0x00C2DB60
(13) section:offset Address Frame
0001:0003C0B2 0xEB58D0B2 0x00C2DD30
(14) section:offset Address Frame
0001:00028DF0 0x13099DF0 0x00C2DD80
Module: C:\Program Files\Autodesk\Maya2012\bin\OpenMaya.dll (-exported-)
Decl: public: virtual int THcommandObject::doIt(class TargList & ptr64)
(15) section:offset Address Frame
0001:00012C9F 0x019B3C9F 0x00C2DDF0
Module: C:\Program Files\Autodesk\Maya2012\bin\CommandEngine.dll (-exported-)
Decl: public: virtual bool TmetaCommand::doCommand(class TargList & ptr64)
(16) section:offset Address Frame
0001:0001372B 0x019B472B 0x00C2DEC0
Decl: private: virtual class Tsyntax * ptr64 TmetaCommand::newSyntax(void)
(17) section:offset Address Frame
0001:000554BE 0x019F64BE 0x00C2E2F0
Decl: setMelGlobalStackLevelPtr
(18) section:offset Address Frame
0001:00029BC0 0x019CABC0 0x00C2E340
Location: TmelVariableList::`default constructor closure' + 0xB0 bytes
Decl: public: void TmelVariableList::`default constructor closure'(void)
(19) section:offset Address Frame
0001:00035F64 0x019D6F64 0x00C2E390
Location: TmelVariableList::`default constructor closure' + 0xC454 bytes
(20) section:offset Address Frame
0001:000534C0 0x019F44C0 0x00C2E3C0
Decl: public: union Value * ptr64 SophiaExecutable::evaluate(void * ptr64)
(21) section:offset Address Frame
0001:00019C1C 0x019BAC1C 0x00C2E400
Decl: public: int TcommandEngine::executeCommand(class SophiaExecutable * ptr64,void * ptr64)
(22) section:offset Address Frame
0001:000214A6 0x01D224A6 0x00C2E430
Module: C:\Program Files\Autodesk\Maya2012\bin\ExtensionLayer.dll (-exported-)
Location: TrepeatCommandManager::executeCommand + 0x1966 bytes
Decl: public: bool TrepeatCommandManager::executeCommand(short,bool)
(23) section:offset Address Frame
0001:0001372B 0x019B472B 0x00C2E500
(24) section:offset Address Frame
0001:00029BC0 0x019CABC0 0x00C2E550
(25) section:offset Address Frame
0001:00055351 0x019F6351 0x00C2E580
(26) section:offset Address Frame
0001:0005499A 0x019F599A 0x00C2E5D0
(27) section:offset Address Frame
0001:00029BC0 0x019CABC0 0x00C2E620
(28) section:offset Address Frame
0001:00054A44 0x019F5A44 0x00C2E670
(29) section:offset Address Frame
0001:00029BC0 0x019CABC0 0x00C2E6C0
(30) section:offset Address Frame
0001:00054A44 0x019F5A44 0x00C2E710
(31) section:offset Address Frame
0001:00029BC0 0x019CABC0 0x00C2E760
(32) section:offset Address Frame
0001:00054D85 0x019F5D85 0x00C2E8B0
(33) section:offset Address Frame
0001:00029BC0 0x019CABC0 0x00C2E900
(34) section:offset Address Frame
0001:000558CD 0x019F68CD 0x00C2F080
(35) section:offset Address Frame
0001:00029BC0 0x019CABC0 0x00C2F0D0
(36) section:offset Address Frame
0001:000558CD 0x019F68CD 0x00C2F580
(37) section:offset Address Frame
0001:00029BC0 0x019CABC0 0x00C2F5D0
(38) section:offset Address Frame
0001:00055351 0x019F6351 0x00C2F600
(39) section:offset Address Frame
0001:00054A7A 0x019F5A7A 0x00C2F650
(40) section:offset Address Frame
0001:00029BC0 0x019CABC0 0x00C2F6A0
(41) section:offset Address Frame
0001:00029BC0 0x019CABC0 0x00C2F6F0
(42) section:offset Address Frame
0001:00035F64 0x019D6F64 0x00C2F740
(43) section:offset Address Frame
0001:000534C0 0x019F44C0 0x00C2F770
(44) section:offset Address Frame
0001:0001A204 0x019BB204 0x00C2F7F0
Decl: public: int TcommandEngine::sourceFile(class Tstring const & ptr64)
(45) section:offset Address Frame
0001:00006BC9 0x40007BC9 0x00C2F8E0
Module: C:\Program Files\Autodesk\Maya2012\bin\mayabatch.exe (-nosymbols-)
(46) section:offset Address Frame
0001:0000233A 0x4000333A 0x00C2F930
(47) section:offset Address Frame
0001:0000A8C7 0x01D0B8C7 0x00C2FA30
Decl: public: void Tapplication::start(void)
(48) section:offset Address Frame
0001:00000B8E 0x40001B8E 0x00C2FF20
(49) section:offset Address Frame
0001:00010FA2 0x40011FA2 0x00C2FF50
(50) section:offset Address Frame
0001:0001552D 0x77A5652D 0x00C2FF80
Module: C:\Windows\system32\kernel32.dll (-exported-)
Decl: BaseThreadInitThunk
(51) section:offset Address Frame
0001:0002B521 0x77C8C521 0x00C2FFD0
Module: C:\Windows\SYSTEM32\ntdll.dll (-exported-)
Decl: RtlUserThreadStart
End of stack
//crash file = C:\Users\JOHANN~1.ENZ\AppData\Local\Temp\MayaCrashLog130204.1904.log
//version = 2012.01.17.2019
//cut = Tue 01/17/2012, 201201172019
//Memory usage:
// 2048.000 Mb Free Memory
// 2048.000 Mb Free Swap
// 5131.543 Mb Current
// 845.746 Mb Arrays
// 15.669 Mb Transforms
// 50.205 Mb Data Blocks
// 9.453 Mb MEL
// 0.002 Mb arguments
// 7.910 Mb Pixel Map
// 0.125 Mb Keys
// 0.166 Mb Object Arrays
fbb
Thank you.
But the .log file is usable only as the second part to .dmp file. Can you please send me the .dmp file too (just attach the files to post, no need to post the content here)?
fbb
ok. here is a zip file with all the crash output files
crash_log_fbb.zip
(36.81 KiB) Downloaded 273 times
fbb
Thank you!
Return to “Autodesk Maya”
